I uninstalled java following this tutorial and then I tried to install it again. I typed:
sudo apt-get update
all good and then I run this sudo apt-get install default-jdk and I get :
Reading package lists... Done
Building dependency tree
 default-jdk : Depends: default-jre (= 1:1.6-43ubuntu2)
               Depends: openjdk-6-jdk (>= 6b23~pre11-1ubuntu1~) but it is not going to be installed
How can I resolve this please?
I have tried
sudo apt-get clean
sudo apt-get autoclean
sudo apt-get -f install
which prints
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
then:
sudo dpkg --configure -a
which prints
I have also tried:
sudo apt-get install -f default-jre openjdk-6-jdk  # I also get the same error without the -f option
which prints:
 default-jre : Depends: openjdk-6-jre (>= 6b23~pre11-1ubuntu1~)
 openjdk-6-jdk : Depends: openjdk-6-jre (= 6b39-1.13.11-0ubuntu0.12.04.1)
                 Recommends: libxt-dev but it is not going to be installed
yaylitzis
  • 731
  • 16
I tried to install sudo apt-get install openjdk-6-jre and then I got that some other package was missing. Then I tried to install that package and then I got some other package was missing.
After 3 times, I installed the last package successfully and I started installing all the missing packages from the end, and then I finally installed it!
yaylitzis
  • 731
  • 16
