I have Ubuntu 22.04 installed on a Virtualbox VM running on Windows 10.
I have to switch the current version of Java installed on my Ubuntu to Java 17, which is the most recent version guaranteed to work fine with some software I need to use.
So I have tryed to uninstall the actual version of Java (Java 11, and before I did it for Java 18).
In order to do so, I have followed this procedure of @Eric Carvalho.
Unfortuately, It also removed some OS files from Ubuntu, and now my VM does not work well anymore.
Luckily I had a backup of the whole VM on Windows ( C > users > MYUSER > VirtualBox VMs ), so I deleted the modified VM and started anew.
So now, How can I safely upgrade/switch from any version of Java to Java 17 on Ubuntu 22.04 ?
Tms91
  • 595
I have re-done the procedure indicated in the question, but instead of runnning
dpkg -l | grep ^rc | awk '{print($2)}' | xargs sudo apt-get -y purge
I have runned
It prints a list of path.
Select only the having 'java' and 'jdk' in the name.
In my case they are the following ones:
  1. ca-certificates-java
  2. java-common
  3. openjdk-11-jre-headless:amd64
Put them as arguments of
sudo apt-get purge <target>
so , in my case:
sudo apt-get purge ca-certificates-java
sudo apt-get purge java-common
sudo apt-get purge openjdk-11-jre-headless:amd64
then I went on with the other steps of the procedure, until I got to its end.
Finally I rebooted my PC
and installed Java 17, with the following command
sudo apt update
sudo apt install openjdk-17-jdk
Tms91
  • 595
