16
Note about possible duplicate:
AFAIK, This is not a duplicate of How do I resolve unmet dependencies after adding a PPA? otherwise please prove it by solving the test problem I mention below using any answer from there.
Background:
I faced this problem before How to fix installation wine on Ubuntu 14.04.3LTS 64 bit. It was solved by manual/human review of all recursive dependencies of the target package (wine).
Reproduce the problem (Test Case):
Let's create same situation quiet simplified with just 1 trouble package.
  1. Install fresh Ubuntu 14.04 on VirtualBox.
  2. Open software-properties-gtk and enable backports repository.
  3. Get last packages list
    sudo apt-get update
  4. Run apt-get -s install wine to confirm that wine can be installed.
  5. Install the troubling package libcgmanager0 from backports
    $ apt-cache policy libcgmanager0
    libcgmanager0:
      Installed: 0.24-0ubuntu5
      Candidate: 0.24-0ubuntu7.5
      Version table:
         0.39-2ubuntu2~ubuntu14.04.1 0
            100 http://dz.archive.ubuntu.com/ubuntu/ trusty-backports/main amd64 Packages
         0.24-0ubuntu7.5 0
            500 http://dz.archive.ubuntu.com/ubuntu/ trusty-updates/main amd64 Packages
         0.24-0ubuntu7.1 0
            500 http://security.ubuntu.com/ubuntu/ trusty-security/main amd64 Packages
     *** 0.24-0ubuntu5 0
            500 http://dz.archive.ubuntu.com/ubuntu/ trusty/main amd64 Packages
            100 /var/lib/dpkg/status
    Force apt to install libcgmanager0 version 0.39-2ubuntu2~ubuntu14.04.1
    sudo apt-get install libcgmanager0=0.39-2ubuntu2~ubuntu14.04.1
Now we end up in same situation of the user from the mentioned question in the background, wine installation fails with unmet dependency, showing only the first level dependency packages.
  • apt-get -s install wine
    Reading package lists... Done
    Building dependency tree
     wine : Depends: wine1.6 but it is not going to be installed
  • apt-get -s install wine1.6
     wine1.6 : Depends: wine1.6-i386 (= 1:1.6.2-0ubuntu4)
  • apt-get -s install wine1.6-i386
     wine1.6-i386:i386 : Depends: libglu1-mesa:i386 but it is not going to be installed or
                                  libglu1:i386
                         Depends: libgphoto2-6:i386 (>= 2.5.2) but it is not going to be installed
                         Depends: libgphoto2-port10:i386 (>= 2.5.2) but it is not going to be installed
                         Recommends: libsane:i386 but it is not going to be installed
It is not practical to follow dependencies with apt-get install one by one.
Ideal Solution:
The real issue here
  1. apt couldn't install libcgmanager0:i386 version 0.39-2ubuntu2~ubuntu14.04.1 because backports repository have a lower priority 100 less then version 0.24-0ubuntu7.5 from updates repository with 500
  2. apt couldn't install libcgmanager0:i386 version 0.24-0ubuntu7.5 because libcgmanager0:amd64 is installed with a different version 0.39-2ubuntu2~ubuntu14.04.1
The quickest fix is, to force installing same i386 version from backports
sudo apt-get install libcgmanager0:i386=0.39-2ubuntu2~ubuntu14.04.1
or downgrade it (amd64) to any version from regular repositories
sudo apt-get install libcgmanager0=0.24-0ubuntu7.5
Ways/tools I have tried:
  • Disabling PPA's has no relation to the problem.
  • Using aptitudein interactive mode, brings only solutions with many removes (>200 !!!).
  • Use apt-get install manually following the dependency tree. Unpractical, as the first & second level dependencies didn't raise meaningful message about the conflict.
  • debfoster can generate the recursive dependencies but only for already installed package. However wine is not yet installed.
Topic / My interests:
Let's say I want to install wine without knowing about the problem of libcgmanager0 package (or exactly libcgmanager0:amd64=0.39-2ubuntu2~ubuntu14.04.1 that already installed).
I'm looking for a debug method or a way to know the name of the troubling package and to understand quickly what was going on.
  1. How to debug unmet dependencies problems in general?
    May be there some new options in dpkg/apt/aptitude that trace the internal dependency resolver. That can show libcgmanager0 in its output.
  2. If there is no canonical answer to this, Could anyone show me a better way to generate the recursive dependencies list or simulate the dependency resolver with more details which can help fix the problem?
    Why all dependencies? Because I want to check the output of the below commands for all packages at once.
    • apt-cache policy <all-dependencies>
    • apt-get -s install <all-dependencies>
user.dz
  • 49,176
Root cause for this case (Wine has a multi-architecture package)
After few years here in Ask Ubuntu. I could notice one thing that could help for this case.
  • apt, aptitude & dpkg don't indicate architecture if it is main the one (amd64 generally), so they always show package-name without the architecture. While they put the architecture suffix on other architectures package-name:i368 for example.
This creates confusion for new users as it happened to me. I was going with assumption that they are same package. examples:
         libcgmanager0 : Breaks: libcgmanager0:i386 (!= 0.39-2ubuntu2~ubuntu14.04.1) but 0.24-0ubuntu7.5 is to be installed.
         libcgmanager0:i386 : Breaks: libcgmanager0 (!= 0.24-0ubuntu7.5) but 0.39-2ubuntu2~ubuntu14.04.1 is installed.
They actually mean this:
         libcgmanager0:amd64 : Breaks: libcgmanager0:i386 (!= 0.39-2ubuntu2~ubuntu14.04.1) but 0.24-0ubuntu7.5 **is to be** installed.
         libcgmanager0:i386 : Breaks: libcgmanager0:amd64 (!= 0.24-0ubuntu7.5) but 0.39-2ubuntu2~ubuntu14.04.1 **is** installed.
Things to watch for resolve general unmet dependency case
  • Dependencies package name
    Some include major version as part of package name NOT package version.
  • Dependencies package architecture
    Default architecture is not mentioned. Common installed systems are amd64 there may be exceptions. Most conflict happen as in this case one of the architectures will not install or upgrade if the other architecture of same package is not available with same version. This is already declared in the package dependency condition.
  • Dependencies package source
    Conflict usually come when dealing with external repositories and ppa's.
Helpful Debug & Troubleshooting commands
Credits & Thanks go to @muru.
I was looking any command or debug option that can show me the trouble package name (libcgmanager0 in this test case).
It has a verbose output, quiet hard to understand it. It should be fine, if I get familiar with it.
Minimum output but clear notice about the conflict.
Another point I was looking for, is to minimize the output requested from the OP support here in Ask Ubuntu. Instead for requesting apt-cache policy for just 1st/2nd level dependencies. I would request it for all recursive dependencies all at once.
Be aware that apt-rdepends is emulating apt-cache so its result may be different than of debfoster. Another point, both tools do not distinguish between arch (i386 or amd64), they just show names.
    apt-cache policy $(apt-rdepends wine 2>/dev/null | grep "^[a-zA-Z]" | sort | paste -s -d" ")
As link above may be removed later, here is the full output of all commands above.
$ apt-get -s -o Debug::pkgProblemResolver=yes install wine
NOTE: This is only a simulation!
      apt-get needs root privileges for real execution.
      Keep also in mind that locking is deactivated,
      so don't depend on the relevance to the real current situation!
Starting pkgProblemResolver with broken count: 1
Starting 2 pkgProblemResolver with broken count: 1
Investigating (0) libudev1 [ i386 ] < none -> 204-5ubuntu20.15 > ( libs )
Broken libudev1:i386 Depends on libcgmanager0 [ i386 ] < none -> 0.24-0ubuntu7.5 | 0.39-2ubuntu2~ubuntu14.04.1 > ( admin )
  Considering libcgmanager0:i386 1 as a solution to libudev1:i386 4
  Holding Back libudev1:i386 rather than change libcgmanager0:i386
Investigating (0) libusb-1.0-0 [ i386 ] < none -> 2:1.0.17-1ubuntu2 > ( libs )
Broken libusb-1.0-0:i386 Depends on libudev1 [ i386 ] < none -> 204-5ubuntu20.15 > ( libs ) (>= 183)
  Considering libudev1:i386 4 as a solution to libusb-1.0-0:i386 1
  Holding Back libusb-1.0-0:i386 rather than change libudev1:i386
Investigating (0) libgl1-mesa-glx [ i386 ] < none -> 11.0.4~git20151026+11.0.ec14e6f8-0ubuntu0ricotz~trusty > ( libs )
Broken libgl1-mesa-glx:i386 Depends on libudev1 [ i386 ] < none -> 204-5ubuntu20.15 > ( libs )
  Considering libudev1:i386 4 as a solution to libgl1-mesa-glx:i386 0
  Holding Back libgl1-mesa-glx:i386 rather than change libudev1:i386
Investigating (0) libsane [ i386 ] < none -> 1.0.23-3ubuntu3.1 > ( libs )
Broken libsane:i386 Depends on libusb-1.0-0 [ i386 ] < none -> 2:1.0.17-1ubuntu2 > ( libs ) (>= 2:1.0.8)
  Considering libusb-1.0-0:i386 1 as a solution to libsane:i386 0
  Holding Back libsane:i386 rather than change libusb-1.0-0:i386
Investigating (0) libgphoto2-port10 [ i386 ] < none -> 2.5.3.1-1ubuntu2.2 > ( libs )
Broken libgphoto2-port10:i386 Depends on libusb-1.0-0 [ i386 ] < none -> 2:1.0.17-1ubuntu2 > ( libs ) (>= 2:1.0.8)
  Considering libusb-1.0-0:i386 1 as a solution to libgphoto2-port10:i386 -1
  Holding Back libgphoto2-port10:i386 rather than change libusb-1.0-0:i386
Investigating (0) libgphoto2-6 [ i386 ] < none -> 2.5.3.1-1ubuntu2.2 > ( libs )
Broken libgphoto2-6:i386 Depends on libgphoto2-port10 [ i386 ] < none -> 2.5.3.1-1ubuntu2.2 > ( libs ) (>= 2.5.2)
  Considering libgphoto2-port10:i386 -1 as a solution to libgphoto2-6:i386 -1
  Holding Back libgphoto2-6:i386 rather than change libgphoto2-port10:i386
Investigating (0) libglu1-mesa [ i386 ] < none -> 9.0.0-2 > ( libs )
Broken libglu1-mesa:i386 Depends on libgl1-mesa-glx [ i386 ] < none -> 11.0.4~git20151026+11.0.ec14e6f8-0ubuntu0ricotz~trusty > ( libs )
  Considering libgl1-mesa-glx:i386 0 as a solution to libglu1-mesa:i386 -1
  Holding Back libglu1-mesa:i386 rather than change libgl1-mesa-glx:i386
Broken libglu1-mesa:i386 Depends on libgl1 [ i386 ] < none > ( none )
  Holding Back libglu1-mesa:i386 rather than change libgl1:i386
  Or group keep for libglu1-mesa:i386
Investigating (1) wine1.6-i386 [ i386 ] < none -> 1:1.6.2-0ubuntu4 > ( universe/otherosfs )
Broken wine1.6-i386:i386 Depends on libglu1-mesa [ i386 ] < none -> 9.0.0-2 > ( libs )
  Considering libglu1-mesa:i386 -1 as a solution to wine1.6-i386:i386 -1
  Holding Back wine1.6-i386:i386 rather than change libglu1-mesa:i386
Broken wine1.6-i386:i386 Depends on libglu1 [ i386 ] < none > ( none )
  Holding Back wine1.6-i386:i386 rather than change libglu1:i386
  Or group keep for wine1.6-i386:i386
Broken wine1.6-i386:i386 Depends on libgphoto2-6 [ i386 ] < none -> 2.5.3.1-1ubuntu2.2 > ( libs ) (>= 2.5.2)
  Considering libgphoto2-6:i386 -1 as a solution to wine1.6-i386:i386 -1
  Holding Back wine1.6-i386:i386 rather than change libgphoto2-6:i386
Investigating (2) wine1.6 [ amd64 ] < none -> 1:1.6.2-0ubuntu4 > ( universe/otherosfs )
Broken wine1.6:amd64 Depends on wine1.6-i386 [ amd64 ] < none > ( none ) (= 1:1.6.2-0ubuntu4)
  Considering wine1.6-i386:i386 -1 as a solution to wine1.6:amd64 0
  Holding Back wine1.6:amd64 rather than change wine1.6-i386:amd64
Investigating (2) wine1.6-amd64 [ amd64 ] < none -> 1:1.6.2-0ubuntu4 > ( universe/otherosfs )
Broken wine1.6-amd64:amd64 Depends on wine1.6:any [ amd64 ] < none > ( none ) (= 1:1.6.2-0ubuntu4)
  Considering wine1.6:i386 -1 as a solution to wine1.6-amd64:amd64 -1
  Holding Back wine1.6-amd64:amd64 rather than change wine1.6:any:amd64
Investigating (3) wine [ amd64 ] < none -> 1:1.6.2-0ubuntu4 > ( universe/otherosfs )
Broken wine:amd64 Depends on wine1.6 [ amd64 ] < none -> 1:1.6.2-0ubuntu4 > ( universe/otherosfs )
  Considering wine1.6:amd64 0 as a solution to wine:amd64 9999
  Re-Instated wine1.6-amd64:amd64
    Reinst Failed because of libcgmanager0:i386
    Reinst Failed because of libudev1:i386
    Reinst Failed because of libgl1-mesa-glx:i386
    Reinst Failed because of libglu1-mesa:i386
    Reinst Failed because of wine1.6-i386:i386
Investigating (3) wine1.6-amd64 [ amd64 ] < none -> 1:1.6.2-0ubuntu4 > ( universe/otherosfs )
Investigating (4) wine [ amd64 ] < none -> 1:1.6.2-0ubuntu4 > ( universe/otherosfs )
Done
The following packages have unmet dependencies: wine : Depends: wine1.6 but it is not going to be installed E: Unable to correct problems, you have held broken packages.
$ echo q | aptitude -s install wine The following NEW packages will be installed: attr{a} binfmt-support{a} cabextract{a} fonts-horai-umefont{a} fonts-unfonts-core{a} fonts-wqy-microhei{a} gcc-4.8-base:i386{a} gcc-4.9-base:i386{a} gnome-exe-thumbnailer{a} icoutils{a} imagemagick{a} imagemagick-common{a} libaio1{a} libasn1-8-heimdal:i386{a} libasound2:i386{a} libasound2-plugins:i386{a} libasyncns0:i386{a} libavahi-client3:i386{a} libavahi-common-data:i386{a} libavahi-common3:i386{a} libc6:i386{a} libcapi20-3{a} libcapi20-3:i386{a} libcgmanager0:i386{ab} libcomerr2:i386{a} libcups2:i386{a} libdb5.3:i386{a} libdbus-1-3:i386{a} libdrm-amdgpu1{a} libdrm-amdgpu1:i386{a} libdrm-intel1:i386{a} libdrm-nouveau2:i386{a} libdrm-radeon1:i386{a} libdrm2:i386{a} libedit2:i386{a} libelf1:i386{a} libencode-locale-perl{a} libexif12:i386{a} libexpat1:i386{a} libffi6:i386{a} libfftw3-double3{a} libfile-listing-perl{a} libflac8:i386{a} libfont-afm-perl{a} libfontconfig1:i386{a} libfreetype6:i386{a} libgcc1:i386{a} libgcrypt11:i386{a} libgd3:i386{a} libgif4{a} libgif4:i386{a} libgl1-mesa-dri:i386{a} libgl1-mesa-glx:i386{a} libglapi-mesa:i386{a} libglib2.0-0:i386{a} libglu1-mesa:i386{a} libgnutls26:i386{a} libgpg-error0:i386{a} libgphoto2-6:i386{a} libgphoto2-port10:i386{a} libgpm2:i386{a} libgssapi-krb5-2:i386{a} libgssapi3-heimdal:i386{a} libgstreamer-plugins-base0.10-0:i386{a} libgstreamer0.10-0:i386{a} libhcrypto4-heimdal:i386{a} libhdb9-heimdal{a} libheimbase1-heimdal:i386{a} libheimntlm0-heimdal:i386{a} libhtml-form-perl{a} libhtml-format-perl{a} libhtml-parser-perl{a} libhtml-tagset-perl{a} libhtml-tree-perl{a} libhttp-cookies-perl{a} libhttp-daemon-perl{a} libhttp-date-perl{a} libhttp-message-perl{a} libhttp-negotiate-perl{a} libhx509-5-heimdal:i386{a} libice6:i386{a} libieee1284-3:i386{a} libilmbase6{a} libio-html-perl{a} libjack-jackd2-0:i386{a} libjbig0:i386{a} libjpeg-turbo8:i386{a} libjpeg8:i386{a} libjson-c2:i386{a} libk5crypto3:i386{a} libkdc2-heimdal{a} libkeyutils1:i386{a} libkrb5-26-heimdal:i386{a} libkrb5-3:i386{a} libkrb5support0:i386{a} liblcms2-2:i386{a} libldap-2.4-2:i386{a} libllvm3.6{a} libllvm3.6:i386{a} liblqr-1-0{a} libltdl7:i386{a} liblwp-mediatypes-perl{a} liblwp-protocol-https-perl{a} liblzma5:i386{a} libmagickcore5{a} libmagickcore5-extra{a} libmagickwand5{a} libmpg123-0{a} libmpg123-0:i386{a} libncurses5:i386{a} libnet-http-perl{a} libnetpbm10{a} libnih-dbus1:i386{a} libnih1:i386{a} libnss-winbind{a} libodbc1{a} libogg0:i386{a} libopenal-data{a} libopenal1{a} libopenal1:i386{a} libopenexr6{a} liborc-0.4-0:i386{a} libosmesa6{a} libosmesa6:i386{a} libp11-kit-gnome-keyring:i386{a} libp11-kit0:i386{a} libpam-winbind{a} libpciaccess0:i386{a} libpcre3:i386{a} libpng12-0:i386{a} libpulse0:i386{a} libroken18-heimdal:i386{a} libsamplerate0:i386{a} libsane:i386{a} libsasl2-2:i386{a} libsasl2-modules:i386{a} libsasl2-modules-db:i386{a} libselinux1:i386{a} libsm6:i386{a} libsndfile1:i386{a} libspeexdsp1:i386{a} libsqlite3-0:i386{a} libssl1.0.0:i386{a} libstdc++6:i386{a} libtasn1-6:i386{a} libtiff5:i386{a} libtinfo5:i386{a} libtxc-dxtn-s2tc0:i386{a} libudev1:i386{a} libusb-1.0-0:i386{a} libuuid1:i386{a} libv4l-0:i386{a} libv4lconvert0:i386{a} libvorbis0a:i386{a} libvorbisenc2:i386{a} libvpx1:i386{a} libwind0-heimdal:i386{a} libwrap0:i386{a} libwww-perl{a} libwww-robotrules-perl{a} libx11-6:i386{a} libx11-xcb1:i386{a} libxau6:i386{a} libxcb-dri2-0:i386{a} libxcb-dri3-0:i386{a} libxcb-glx0:i386{a} libxcb-present0:i386{a} libxcb-sync1:i386{a} libxcb1:i386{a} libxcomposite1:i386{a} libxcursor1:i386{a} libxdamage1:i386{a} libxdmcp6:i386{a} libxext6:i386{a} libxfixes3:i386{a} libxi6:i386{a} libxinerama1:i386{a} libxml2:i386{a} libxpm4:i386{a} libxrandr2:i386{a} libxrender1:i386{a} libxshmfence1:i386{a} libxslt1.1:i386{a} libxt6:i386{a} libxxf86vm1:i386{a} netpbm{a} ocl-icd-libopencl1{a} ocl-icd-libopencl1:i386{a} odbcinst{a} odbcinst1debian2{a} p11-kit-modules:i386{a} p7zip{a} python-dnspython{a} samba{a} samba-dsdb-modules{a} samba-vfs-modules{a} tdb-tools{a} ttf-mscorefonts-installer{a} ttf-wqy-microhei{a} unixodbc{a} winbind{a} wine wine-gecko2.21{a} wine-gecko2.21:i386{a} wine-mono0.0.8{a} wine1.6{a} wine1.6-amd64{a} wine1.6-i386:i386{a} winetricks{a} zlib1g:i386{a} The following packages will be upgraded: libgl1-mesa-dri 1 packages upgraded, 210 newly installed, 0 to remove and 11 not upgraded. Need to get 200 MB of archives. After unpacking 646 MB will be used. The following packages have unmet dependencies: libcgmanager0 : Breaks: libcgmanager0:i386 (!= 0.39-2ubuntu2~ubuntu14.04.1) but 0.24-0ubuntu7.5 is to be installed. libcgmanager0:i386 : Breaks: libcgmanager0 (!= 0.24-0ubuntu7.5) but 0.39-2ubuntu2~ubuntu14.04.1 is installed. The following actions will resolve these dependencies:
  Keep the following packages at their current version:
  1.  libcgmanager0:i386 [Not Installed]
  2.  libgl1-mesa-glx:i386 [Not Installed]
  3.  libglu1-mesa:i386 [Not Installed]
  4.  libgphoto2-6:i386 [Not Installed]
  5.  libgphoto2-port10:i386 [Not Installed]
  6.  libsane:i386 [Not Installed]
  7.  libudev1:i386 [Not Installed]
  8.  libusb-1.0-0:i386 [Not Installed]
  9.  wine [Not Installed]
  10. wine1.6 [Not Installed]
  11. wine1.6-amd64 [Not Installed]
  12. wine1.6-i386:i386 [Not Installed]
    Leave the following dependencies unresolved:
  13. winetricks recommends wine
Accept this solution? [Y/n/q/?] Abandoning all efforts to resolve these dependencies. Abort.
$ apt-rdepends wine 2>/dev/null | grep "^[a-zA-Z]" | sort adduser base-passwd binfmt-support busybox-initramfs coreutils cpio debconf debconf-2.0 debianutils dpkg file-rc findutils fontconfig-config fonts-dejavu-core fonts-freefont-ttf gcc-4.8-base gcc-4.9-base gsfonts gsfonts-x11 ifupdown initramfs-tools initramfs-tools-bin initscripts init-system-helpers insserv install-info iproute2 iso-codes klibc-utils kmod libacl1 libasn1-8-heimdal libasound2 libasound2-data libasyncns0 libattr1 libaudit1 libaudit-common libblkid1 libbz2-1.0 libc6 libcgmanager0 libcomerr2 libdb5.3 libdbus-1-3 libdebconfclient0 libdrm2 libexif12 libexpat1 libffi6 libflac8 libfontconfig1 libfontenc1 libfreetype6 libgcc1 libgcrypt11 libgd3 libgdbm3 libgl1 libgl1-mesa-glx libglapi-mesa libglib2.0-0 libglu1 libglu1-mesa libgnutls26 libgpg-error0 libgphoto2-6 libgphoto2-port10 libgssapi3-heimdal libgstreamer0.10-0 libgstreamer-plugins-base0.10-0 libhcrypto4-heimdal libheimbase1-heimdal libheimntlm0-heimdal libhx509-5-heimdal libjbig0 libjpeg8 libjpeg-turbo8 libjson0 libjson-c2 libklibc libkmod2 libkrb5-26-heimdal liblcms2-2 libldap-2.4-2 libltdl7 liblzma5 libmount1 libmpg123-0 libncurses5 libncursesw5 libnih1 libnih-dbus1 libogg0 libopenal1 libopenal-data libopencl1 libopencl-1.1-1 liborc-0.4-0 libp11-kit0 libpam0g libpam-modules libpam-modules-bin libpcre3 libpipeline1 libplymouth2 libpng12-0 libprocps3 libpulse0 libroken18-heimdal libsasl2-2 libsasl2-modules-db libselinux1 libsemanage1 libsemanage-common libsepol1 libslang2 libsndfile1 libsqlite3-0 libstdc++6 libtasn1-6 libtiff5 libtinfo5 libudev0 libudev1 libusb-1.0-0 libustr-1.0-1 libuuid1 libvorbis0a libvorbisenc2 libvpx1 libwind0-heimdal libwrap0 libx11-6 libx11-data libx11-xcb1 libxau6 libxcb1 libxcb-dri2-0 libxcb-dri3-0 libxcb-glx0 libxcb-present0 libxcb-sync1 libxdamage1 libxdmcp6 libxext6 libxfixes3 libxfont1 libxml2 libxpm4 libxshmfence1 libxxf86vm1 lsb-base makedev module-init-tools mount mountall multiarch-support ocl-icd-libopencl1 passwd perl perl-base perl-modules plymouth procps sensible-utils sysvinit-utils sysv-rc tar ttf-bitstream-vera tzdata ucf udev upstart util-linux wine wine1.6 wine1.6-amd64 wine1.6:any wine1.6-i386 x11-common xfonts-encodings xfonts-utils zlib1g
user.dz
  • 49,176
