I am trying to install wine on Ubuntu 15.04, I had it working before but I think something went wrong with 32 or 64 bit installations so I tried removing it to start again.
Now I am trying to install it again but running apt-get install wine
root@pc-ubuntu:/home/dav# apt-get install wine
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies.
 wine : Depends: wine1.6 but it is not going to be installed
E: Unable to correct problems, you have held broken packages`
So I try to fix the broken packages with apt-get install -f
0 to upgrade, 0 to newly install, 0 to remove and 2 not to upgrade.`
I have tried removing and adding the PPA, I have tried a load of other commands pointed out in the answer here How do I resolve unmet dependencies after adding a PPA? But none of them have worked either. I'm stuck, please any suggestions would be amazing to fix this as I would like to sort it before attempting to build the latest wine 1.8 from source. Thanks
Dav
  • 513
None of your packages are broken. The wine dependencies are conflicting with each other. Uninstall existing version of wine (if exists) then install wine1.7 (there won't be such problem with wine1.7)
UPDATE: To install wine 1.7 on your case type these in your terminal:
sudo apt-add-repository ppa:ubuntu-wine/ppa
sudo apt-get update
sudo apt-get install wine1.7
Olimjon
  • 7,522
