I know there are several question about this subject, but some of them do not have any response, and for the ones which do, I have followed all the advices given and nothing fixed my problem. Every time I attempt to give :
sudo apt-get install wine
I get an error about depends on X BUT IT WONT BE INSTALLED with X being some version of wine, for instance wine1.6 or some library its using. I have attempted a MYRIAD of workarounds from all over Google but still I am unable to do it. As a side note, I used the same DVD to install Xubuntu on my mother's PC and I installed it there (Wine) with no issues.
Can someone advice here?
EDIT : Error I am getting :
 wine : Depends: wine1.6
Attempting wine1.6
sudo apt-get install wine1.6
 wine1.6 : Depends: wine1.6-amd64 (= 1:1.6.2-0ubuntu14)
           Depends: wine1.6-i386 (= 1:1.6.2-0ubuntu14)
           Recommends: fonts-droid but it is not installable
Attempting wine1.6-amd64
sudo apt-get install wine1.6-amd64
 wine1.6-amd64 : Depends: wine1.6:any (= 1:1.6.2-0ubuntu14)
                 Recommends: libosmesa6 but it is not going to be installed
Try this following steps to download wine:
  1. Add the PPA via command:
    sudo add-apt-repository ppa:ubuntu-wine/ppa
  2. Update package cache and install wine1.8:
    sudo apt-get update
    sudo apt-get install wine1.8 winetricks
Install latest Wine Dev release from the Official WineHQ PPA:
Open terminal from Unity Dash, App Launcher, or via Ctrl+Alt+T shortcut key. When it opens, paste below commands and run one by one.
  1. For 64-bit system, rum command to enable 32 bit architecture:
    sudo dpkg --add-architecture i386
Type in your password when it asks, no visual feedback so type in mind and hit Enter to continue.
  1. Add the wine PPA:
    sudo add-apt-repository ppa:wine/wine-builds
  2. Once you have the PPA added in your system, run below commands one by one to refresh package caches and install Wine 1.8:
    sudo apt-get update
    sudo apt-get install --install-recommends winehq-devel
    The installation automatically replaces old wine releases installed on your system.
  3. Finally you may run below command to initialize your wine configuration.
    winecfg
sourav
  • 157
