-1
This question is not a dupe. I have received the answer I wanted here: https://unix.stackexchange.com/a/411530/3285
Previously, I was getting this error when I merely tried to update. I believe this problem is related to the VLC PPA which has always been total and utter trash on Ubuntu. I had to actually remove a file that was under package control with rm in order to purge the *vlc* packages. Now, that I deleted that file, I was able to relatively easily delete the vlc packages. I figured this would take me back to the begining and I could again try to install, but when I do I get this error,
sudo apt-get install vlc
Reading package lists... Done
Building dependency tree
 vlc : Depends: vlc-plugin-video-output (= 3.0.0~rc1~~git20171215+r73271+108~ubuntu17.10.1) but it is not going to be installed
Now, a few things
  • I don't want to use Aptitude! That's not a solution, as was suggested here. I want to know what the problem is.
  • I don't have any marked packages. These commands return nothing.
    dpkg --get-selections | grep hold
    apt-mark showhold
  • I have nothing with vlc. This command returns nothing.
    dpkg -l | grep -i vlc
Where can I go looking for what is causing this problem?
sudo apt-get -s -o Debug::pkgProblemResolver=yes install vlc
Starting pkgProblemResolver with broken count: 1
Starting 2 pkgProblemResolver with broken count: 1
Investigating (0) vlc:amd64 < none -> 3.0.0~rc1~~git20171215+r73271+108~ubuntu17.10.1 @un puN Ib >
Broken vlc:amd64 Depends on vlc-plugin-base:amd64 < none | 3.0.0~rc1~~git20171215+r73271+108~ubuntu17.10.1 @un uH > (= 3.0.0~rc1~~git20171215+r73271+108~ubuntu17.10.1)
  Considering vlc-plugin-base:amd64 0 as a solution to vlc:amd64 9999
  Re-Instated vlc-plugin-base:amd64
Investigating (0) vlc-plugin-video-output:amd64 < none -> 3.0.0~rc1~~git20171215+r73271+108~ubuntu17.10.1 @un uN Ib >
Broken vlc-plugin-video-output:amd64 Breaks on vlc-plugin-base:amd64 < none -> 3.0.0~rc1~~git20171215+r73271+108~ubuntu17.10.1 @un uN > (< 3.0.0~rc1~20171206-1~)
  Considering vlc-plugin-base:amd64 0 as a solution to vlc-plugin-video-output:amd64 0
  Holding Back vlc-plugin-video-output:amd64 rather than change vlc-plugin-base:amd64
Investigating (1) vlc:amd64 < none -> 3.0.0~rc1~~git20171215+r73271+108~ubuntu17.10.1 @un puN Ib >
Broken vlc:amd64 Depends on vlc-plugin-video-output:amd64 < none | 3.0.0~rc1~~git20171215+r73271+108~ubuntu17.10.1 @un uH > (= 3.0.0~rc1~~git20171215+r73271+108~ubuntu17.10.1)
  Considering vlc-plugin-video-output:amd64 0 as a solution to vlc:amd64 9999
  Re-Instated vlc-plugin-video-output:amd64
Investigating (1) vlc-plugin-video-output:amd64 < none -> 3.0.0~rc1~~git20171215+r73271+108~ubuntu17.10.1 @un uN Ib >
Investigating (2) vlc:amd64 < none -> 3.0.0~rc1~~git20171215+r73271+108~ubuntu17.10.1 @un puN Ib >
Done
It was requested that I try apt-get -f install,
sudo apt-get install -f
[sudo] password for ecarroll:
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Running a quick check with apt-cache policy as requested,
apt-cache policy vlc vlc-plugin-video-output vlc-plugin-base
vlc:
  Installed: (none)
  Candidate: 3.0.0~rc1~~git20171215+r73271+108~ubuntu17.10.1
  Version table:
     3.0.0~rc1~~git20171215+r73271+108~ubuntu17.10.1 500
        500 http://ppa.launchpad.net/videolan/master-daily/ubuntu artful/main amd64 Packages
     2.2.6-6 500
        500 http://us.archive.ubuntu.com/ubuntu artful/universe amd64 Packages
  Installed: (none)
  Version table:
     2.2.6-6 500
vlc-plugin-base:
  Installed: (none)
  Version table:
     2.2.6-6 500
Running, sudo apt-get install vlc vlc-plugin-video-output vlc-plugin-base
 vlc-plugin-video-output : Breaks: vlc-plugin-base (< 3.0.0~rc1~20171206-1~) but 3.0.0~rc1~~git20171215+r73271+108~ubuntu17.10.1 is to be installed
Running, apt-cache show vlc-plugin-video-output vlc-plugin-base
Package: vlc-plugin-video-output
Source: vlc
Priority: optional
Section: video
Installed-Size: 747
Maintainer: Debian Multimedia Maintainers <pkg-multimedia-maintainers@lists.alioth.debian.org>
Architecture: amd64
Version: 3.0.0~rc1~~git20171215+r73271+108~ubuntu17.10.1
Replaces: vlc-plugin-base (<< 3.0.0~rc1~20171206-1~)
Depends: libaa1 (>= 1.4p5), libavcodec57 (>= 7:3.3.4) | libavcodec-extra57 (>= 7:3.3.4), libavutil55 (>= 7:3.3.4), libc6 (>= 2.16), libcaca0 (>= 0.99.beta17-1), libegl1-mesa (>= 7.8.1) | libegl1-x11, libgl1-mesa-glx | libgl1, libgles2-mesa (>= 7.8.1) | libgles2, libva-drm1 (>= 1.1.0), libva-wayland1 (>= 1.3.0), libva-x11-1 (>= 1.0.3), libva1 (>= 1.7.3), libvlccore9 (>= 3.0.0~rc1~~git20171215+r73271+108~ubuntu17.10.1~), libwayland-client0 (>= 1.9.91), libwayland-egl1-mesa (>= 10.0.2) | libwayland-egl1, libx11-6, libxcb-keysyms1 (>= 0.4.0), libxcb-shm0, libxcb-xv0 (>= 1.2), libxcb1, vlc-plugin-abi-4-0-0
Enhances: vlc
Breaks: vlc-plugin-base (<< 3.0.0~rc1~20171206-1~)
Filename: pool/main/v/vlc/vlc-plugin-video-output_3.0.0~rc1~~git20171215+r73271+108~ubuntu17.10.1_amd64.deb
MD5sum: 0d25595004292437bbc298de8ce0ffdd
SHA1: 4be5a204b9aeedfc444e8520010fc3ac02363873
SHA256: fb8f64cb8ba1344e73e666c0621a974ccc313ffcbe8c38760765e40f9c0b637d
Description-en: multimedia player and streamer (video output plugins)
 VLC is the VideoLAN project's media player. It plays MPEG, MPEG-2, MPEG-4,
 DivX, MOV, WMV, QuickTime, WebM, FLAC, MP3, Ogg/Vorbis files, DVDs, VCDs,
 podcasts, and multimedia streams from various network sources.
 This package contains the video output plugins.
Description-md5: 304efe8a3dcaf595b6085adb45316c41
Multi-Arch: same
Architecture: amd64
Version: 2.2.6-6
Multi-Arch: same
Priority: optional
Section: universe/video
Source: vlc
Origin: Ubuntu
Maintainer: Ubuntu Developers <ubuntu-devel-discuss@lists.ubuntu.com>
Original-Maintainer: Debian Multimedia Maintainers <pkg-multimedia-maintainers@lists.alioth.debian.org>
Bugs: https://bugs.launchpad.net/ubuntu/+filebug
Installed-Size: 249
Depends: libvlccore8 (= 2.2.6-6), libaa1 (>= 1.4p5), libc6 (>= 2.14), libcaca0 (>= 0.99.beta17-1), libegl1-mesa (>= 7.8.1) | libegl1-x11, libgl1-mesa-glx | libgl1, libgles2-mesa (>= 7.8.1) | libgles2, libx11-6, libxcb-keysyms1 (>= 0.4.0), libxcb-shm0, libxcb-xv0 (>= 1.2), libxcb1
Enhances: vlc
Filename: pool/universe/v/vlc/vlc-plugin-video-output_2.2.6-6_amd64.deb
MD5sum: b781e5a9bd6f9f513914f3bd5ab5e5f3
SHA1: 5e7a6a24e7ecb9c3944447303f7a276ec8dd592b
SHA256: e3e66e617cee1e9db3d26b37de8c26b4d8a55901eee3e16c6e1a94f1d37be988
Homepage: https://www.videolan.org/vlc/
Task: kubuntu-desktop, kubuntu-full, edubuntu-desktop-gnome, lubuntu-qt-desktop, ubuntustudio-video, ubuntustudio-graphics, ubuntu-mate-desktop
Package: vlc-plugin-base
Source: vlc
Priority: optional
Section: video
Installed-Size: 10845
Architecture: amd64
Recommends: xdg-utils
Replaces: vlc-plugin-zvbi (<< 3.0.0~rc1~20171206-1~)
Suggests: libdvdcss2
Depends: vlc-data (= 3.0.0~rc1~~git20171215+r73271+108~ubuntu17.10.1), liba52-0.7.4, libarchive13 (>= 3.1.2), libaribb24-0 (>= 1.0.3), libasound2 (>= 1.0.27), libass9 (>= 1:0.13.6), libavahi-client3 (>= 0.6.16), libavahi-common3 (>= 0.6.16), libavc1394-0 (>= 0.5.3), libavcodec57 (>= 7:3.3.4) | libavcodec-extra57 (>= 7:3.3.4), libavformat57 (>= 7:3.3.4), libavutil55 (>= 7:3.3.4), libbasicusageenvironment1, libbluray2 (>= 1:1.0.0), libc6 (>= 2.16), libcairo2 (>= 1.13.1), libcddb2, libchromaprint1 (>= 1.3.2), libcrystalhd3 (>= 1:0.0~git20110715.fdd2f19), libdbus-1-3 (>= 1.9.14), libdc1394-22, libdca0 (>= 0.0.5), libdvbpsi10 (>= 1.3.0), libdvdnav4 (>= 5.0.3), libdvdread4 (>= 4.1.3), libebml4v5 (>= 1.3.4-2~), libfaad2 (>= 2.7), libflac8 (>= 1.3.0), libfontconfig1 (>= 2.11.94), libfreetype6 (>= 2.2.1), libfribidi0 (>= 0.19.2), libgcc1 (>= 1:3.4), libgcrypt20 (>= 1.7.0), libglib2.0-0 (>= 2.28.0), libgnutls30 (>= 3.5.6), libgpg-error0 (>= 1.14), libgroupsock8, libharfbuzz0b (>= 0.9.4), libjpeg8 (>= 8c), libkate1 (>= 0.3.0), liblirc-client0, liblivemedia58, liblua5.2-0, libmad0 (>= 0.15.1b-3), libmatroska6v5 (>= 1.4.5), libmicrodns0 (>= 0.0.3), libmpcdec6 (>= 1:0.1~r435), libmpeg2-4 (>= 0.5.1), libmpg123-0 (>= 1.13.7), libmtp9 (>= 1.1.0), libncursesw5 (>= 6), libnfs8 (>= 1.9.7), libogg0 (>= 1.1.0), libopenmpt-modplug1 (>= 0.2.7386~beta20.3), libopus0 (>= 1.1), libpng16-16 (>= 1.6.2-1), libpostproc54 (>= 7:3.3.4), libpulse0 (>= 0.99.4), libraw1394-11, libresid-builder0c2a, librsvg2-2 (>= 2.14.4), libsamplerate0 (>= 0.1.7), libsdl-image1.2 (>= 1.2.10), libsdl1.2debian (>= 1.2.11), libsecret-1-0 (>= 0.7), libshine3 (>= 3.1.0), libshout3, libsidplay2, libsndio6.1 (>= 1.1.0), libsoxr0 (>= 0.1.0), libspeex1 (>= 1.2~beta3-1), libspeexdsp1 (>= 1.2~beta3.2-1), libssh2-1 (>= 1.2.3), libstdc++6 (>= 5.2), libswscale4 (>= 7:3.3.4), libsystemd0, libtag1v5 (>= 1.9.1-2.2~), libtheora0 (>= 1.0), libtinfo5 (>= 6), libtwolame0 (>= 0.3.6), libudev1 (>= 183), libupnp6 (>= 1:1.6.19), libusageenvironment3, libva-drm1 (>= 1.1.0), libva1 (>= 1.7.3), libvlccore9 (>= 3.0.0~rc1~~git20171215+r73271+108~ubuntu17.10.1~), libvorbis0a (>= 1.1.2), libvorbisenc2 (>= 1.1.2), libx264-148, libx265-130 (>= 2.5), libxcb-keysyms1 (>= 0.4.0), libxcb1, libxml2 (>= 2.7.4), libzvbi0 (>= 0.2.35), zlib1g (>= 1:1.1.4), vlc-plugin-abi-4-0-0
Breaks: vlc-plugin-zvbi (<< 3.0.0~rc1~20171206-1~)
Filename: pool/main/v/vlc/vlc-plugin-base_3.0.0~rc1~~git20171215+r73271+108~ubuntu17.10.1_amd64.deb
MD5sum: 02cfa70575f76df46096e0f9df8dac74
SHA1: 0c45fa13a2c3473e27fdc32d5d4da7bdd0237907
SHA256: fcfc90a4c13a0c695bb342ca980087e1235cdf955173b18c23056615618a288a
Description-en: multimedia player and streamer (base plugins)
 This package contains most plugins which are shipped in more specialied plugin
 packages.
Description-md5: 103cb021db8e172eaddc03ab0f07e203
Multi-Arch: same
Architecture: amd64
Version: 2.2.6-6
Multi-Arch: same
Priority: optional
Source: vlc
Origin: Ubuntu
Installed-Size: 27372
Depends: libvlccore8 (= 2.2.6-6), liba52-0.7.4, libasound2 (>= 1.0.27), libass9 (>= 1:0.13.6), libavahi-client3 (>= 0.6.16), libavahi-common3 (>= 0.6.16), libavc1394-0 (>= 0.5.3), libbasicusageenvironment1, libbluray2 (>= 1:0.5.0), libbz2-1.0, libc6 (>= 2.17), libcairo2 (>= 1.13.1), libcddb2, libcdio13 (>= 0.83), libchromaprint1 (>= 1.3.2), libcrystalhd3 (>= 1:0.0~git20110715.fdd2f19), libdbus-1-3 (>= 1.9.14), libdc1394-22, libdca0 (>= 0.0.5), libdvbpsi10 (>= 1.3.0), libdvdnav4 (>= 5.0.3), libdvdread4 (>= 4.1.3), libebml4v5 (>= 1.3.4-2~), libfaad2 (>= 2.7), libflac8 (>= 1.3.0), libfontconfig1 (>= 2.11.94), libfreetype6 (>= 2.2.1), libfribidi0 (>= 0.19.2), libgcc1 (>= 1:3.4), libgcrypt20 (>= 1.7.0), libglib2.0-0 (>= 2.12.0), libgme0 (>= 0.5.5), libgnutls30 (>= 3.5.6), libgpg-error0 (>= 1.14), libgroupsock8, libgsm1 (>= 1.0.13), libjpeg8 (>= 8c), libkate1 (>= 0.3.0), liblirc-client0, liblivemedia58, liblua5.2-0, liblzma5 (>= 5.1.1alpha+20120614), libmad0 (>= 0.15.1b-3), libmatroska6v5 (>= 1.4.5), libmp3lame0, libmpcdec6 (>= 1:0.1~r435), libmpeg2-4 (>= 0.5.1), libmtp9 (>= 1.1.0), libncursesw5 (>= 6), libogg0 (>= 1.1.0), libopenmpt-modplug1 (>= 0.2.7386~beta20.3), libopus0 (>= 1.1), libpng16-16 (>= 1.6.2-1), libpulse0 (>= 0.99.4), libraw1394-11, libresid-builder0c2a, librsvg2-2 (>= 2.14.4), librtmp1 (>= 2.3), libsamplerate0 (>= 0.1.7), libsdl-image1.2 (>= 1.2.10), libsdl1.2debian (>= 1.2.11), libshine3 (>= 3.1.0), libshout3, libsidplay2, libsnappy1v5, libsndio6.1 (>= 1.1.0), libspeex1 (>= 1.2~beta3-1), libspeexdsp1 (>= 1.2~beta3.2-1), libssh-gcrypt-4 (>= 0.4.2), libssh2-1 (>= 1.2), libstdc++6 (>= 5.2), libtag1v5 (>= 1.9.1-2.2~), libtheora0 (>= 1.0), libtinfo5 (>= 6), libtwolame0 (>= 0.3.10), libudev1 (>= 183), libupnp6 (>= 1:1.6.19), libusageenvironment3, libva-drm1 (>= 1.1.0), libva-x11-1 (>= 1.0.3), libva1 (>= 1.7.3), libvcdinfo0 (>= 0.7.21), libvorbis0a (>= 1.1.2), libvorbisenc2 (>= 1.1.2), libvpx4 (>= 1.6.0), libwavpack1 (>= 4.40.0), libwebp6 (>= 0.5.1), libwebpmux3 (>= 0.6.0-3), libx11-6, libx264-148, libx265-130 (>= 2.5), libxcb-keysyms1 (>= 0.4.0), libxcb1, libxml2 (>= 2.7.4), libxvidcore4 (>= 1.2.2), libzvbi0 (>= 0.2.35), zlib1g (>= 1:1.2.0.2), vlc-data (= 2.2.6-6)
Filename: pool/universe/v/vlc/vlc-plugin-base_2.2.6-6_amd64.deb
MD5sum: 18b84f38bd2569d84b8ad409e0053267
SHA1: e3832d8afbeffc6d320ed42e5a0ad55a25701412
SHA256: e564b23d60b45de85576cb0add1fc31b21586f8c05f24323f148a3cf579951ed
 packages.
terdon
  • 104,119
You have broken dependencies due to the PPA you are using:
You can tell this from the messages:
    vlc : Depends: > vlc-plugin-video-output (=> 3.0.0~rc1~~git20171215+r73271+108~ubuntu17.10.1)
So vlc depends on vlc-plugin-video-output
$ sudo apt-get -s -o Debug::pkgProblemResolver=yes install vlc
  none -> 3.0.0~rc1~~git20171215+r73271+108~ubuntu17.10.1 @un uN  ( 3.0.0~rc1~20171206-1~)
apt is holding vlc-plugin-video-output, due to broken dependencies. Not you nor your configuration, but we already knew that from the very first output.
And we have the exact reason
vlc-plugin-video-output : Breaks: vlc-plugin-base (3.0.0~rc1~20171206-1~) but 3.0.0~rc1~~git20171215+r73271+108~ubuntu17.10.1 is to be installed
So you need to file a bug report with ppa.launchpad.net/videolan/master-daily/ubuntu so that they fix your dependency problem, or resolve it yourself.
I would not advise you to solve it yourself unless you are willing to accept a broken vlc or you know the packages in question.
Such is the risk of using a PPA, especially this one.
Zanna
  • 72,312
Panther
  • 104,528
