I recently updated Ubuntu 14.04 from software updater. After update some packages were removed. after that I found that vlc has been also removed from my system. So I tried to install vlc and its giving a error like this:
mzsbulbul@bulbul-laptop:~$ sudo apt-get install vlc
Reading package lists... Done
Building dependency tree
vlc : Depends: vlc-nox (= 2.2.1-3~ubuntu14.04.1~c42.ppa1) but it is not going to be installed
Depends: libstdc++6 (>= 4.9) but 4.8.4-2ubuntu1~14.04.1 is to be installed
Recommends: vlc-plugin-notify (= 2.2.1-3~ubuntu14.04.1~c42.ppa1) but it is not going to be installed
Recommends: vlc-plugin-samba (= 2.2.1-3~ubuntu14.04.1~c42.ppa1) but it is not going to be installed
I have also tried sudo apt-get -f install & sudo aptitude install vlc but not solved.
