When I try to install R with sudo apt-get install r-base, it says
Reading package lists... Done
Building dependency tree
r-base : Depends: r-base-core (>= 3.2.1-4vivid0) but it is not going
to be installed
Depends: r-recommended (= 3.2.1-4vivid0) but it is not going to be installed
Recommends: r-base-html but it is not going to be installed
