According to this at the Now automate it on login section, I have made my own script 45custom_xrandr-settings and placed it into /etc/X11/Xsession.d/. It works fine for me under Ubuntu 14.04 LTS. You could place the code below after the case command described in that section.
PRI_OUTPUT="DVI-0";
# Make and force resolution
myNewMode=$(cvt 1366 768 60 | grep -oP 'Modeline\K.*') && #grep evrything after 'Modline'
myNewModeName=\"$(echo $myNewMode | grep -oP '"\K[^"\047]+(?=["\047])' )\" && #grep everything inside quotes
xrandr --newmode $myNewMode;
sleep 15;
xrandr --addmode $PRI_OUTPUT $myNewModeName;
I believe that the above is what you are looking for. You can see the available outputs simply by running the xrandr command. The outputs may be VGA, VGA-0, DVI-0, TMDS-1 or DisplayPort-0.
Here is the complete script that I made.
# To configure xrandr automatically during the first login,
# save this script to your computer as /etc/X11/Xsession.d/45custom_xrandr-settings:
# If an external monitor is connected, place it with xrandr
# External output may be "VGA" or "VGA-0" or "DVI-0" or "TMDS-1"
# More info at http://www.thinkwiki.org/wiki/Xorg_RandR_1.2
PRI_OUTPUT="DVI-0";
SEC_OUTPUT="DisplayPort-0";
SEC_LOCATION="left"; # SEC_LOCATION may be one of: left, right, above, or below
case "$SEC_LOCATION" in
left|LEFT)
SEC_LOCATION="--left-of $PRI_OUTPUT"
right|RIGHT)
SEC_LOCATION="--right-of $PRI_OUTPUT"
top|TOP|above|ABOVE)
SEC_LOCATION="--above $PRI_OUTPUT"
bottom|BOTTOM|below|BELOW)
SEC_LOCATION="--below $PRI_OUTPUT"
esac
sleep 15;
# Activate secondary out (display port)
xrandr | grep $SEC_OUTPUT | grep " connected "
if [ $? -eq 0 ]; then
# xrandr --output $SEC_OUTPUT --auto $SEC_LOCATION
xrandr --output $PRI_OUTPUT --mode $myNewModeName --output $SEC_OUTPUT --auto $SEC_LOCATION
else
xrandr --output $PRI_OUTPUT --mode $myNewModeName --output $SEC_OUTPUT --off
fi
