I use Ubuntu 15.10 on my dell Ultrasmall optiplex 760 with a 19" dell display. My display supports a resolution of 1280x1024. But when I start ubuntu the resolution is 1024x768.
After long time googling i have found a solution to be able to force my resolution to 1280x1024 by using these commands in terminal:
sudo cvt 1280 1024 60
sudo xrandr --newmode "1280x1024_60.00"  109.00  1280 1368 1496 1712  1024 1027 1034 1063 -hsync +vsync
sudo xrandr --addmode VGA1 1280x1024_60.00
But when I restart Ubuntu I have to put these commands in the terminal again because the resolution doesn't stay at bootup.
I've found a lot of topics about this to make the resolution stay but none have worked for me because of missing files which I had to edit in order to make it stay at bootup.
Any help would be appreciated as I have been looking to solve this issue for almost a day.
Keep in mind I am a real noob, and therefore every step to take for a solution should be explained to me step by step.
Thanks.
TellMeWhy
  • 17,964
  • 41
  • 100
  • 142
You need to add the xrandr configurations to a startup file, so that you'll get your desired resolution upon reboot/startup:
  • Create a bash script, xrandr.sh for example, and place your xrandr commands into it:
#!/bin/bash
  • Make the script executable with chmod +x xrandr.sh
  • Search for "Startup Applications" in the dash, run it, and add the script as a startup application.
The commands will now run every time you log into your account.
NOTE: You don't use sudo when executing xrandr commands.
TellMeWhy
  • 17,964
  • 41
  • 100
  • 142
