I have a startup command to set my gamma in xgamma; whenever I log in, it flickers briefly to what I have it set to, then goes back to 1. Why? Is there a better way to adjust gamma defaults?
Asked
Active
Viewed 2,713 times
I had the same problem.
The solution for me was to set a sleep command in the bash script for 10 seconds to delay the initiation.
#! /bin/sh
sleep 10
xgamma -rgamma x.xxx -ggamma x.xxx -bgamma x.xxx
This seems to work on 12.10 with HD 4000 graphics (mesa driver)
(If you need to create a script, you open your text editor, paste the lines above in the text file, chage x.xxx values to what you need, and save the file with .sh name ( is you file name))
(Than you want to add script to start up applications, type start up in unity bar, and than add the file in the new window)
Cheers,
user143697
- 31
