I'm trying yet again to switch from Windows to Linux and ran into the follwoing problem: I have a LG 29UM55 Ultrawide Monitor with a Radeon HD5450 card on Ubuntu 16.04. After a couple of hours reading through posts and trying out things I got it working by reducing the refresh rate to 40Hz. Unfortunately after a restart I have to do the whole "xrandr-thing" again, means it lost the resolution again.
I found some posts suggesting to edit the /usr/share/X11/xorg.conf.d/10-monitor.config file but it just won't work! I played around a with it a bit but without success.
$ cvt 2560 1080 40
# 2560x1080 39.93 Hz (CVT) hsync: 44.25 kHz; pclk: 147.25 MHz
Modeline "2560x1080_40.00"  147.25  2560 2680 2944 3328  1080 1083 1093 1108 -hsync +vsync
$ sudo xrandr --newmode "2560x1080_40.00" 147.25 2560 2680 2944 3328 1080 1083 1093 1108 -hsync +vsync
$ sudo xrandr --addmode HDMI-0 2560x1080_40.00
$ xrandr
Screen 0: minimum 320 x 200, current 2560 x 1080, maximum 8192 x 8192
HDMI-0 connected primary 2560x1080+0+0 (normal left inverted right x axis y axis) 677mm x 290mm
   1920x1080     60.00    50.00    59.94    30.00    29.97
   1920x1080i    60.00    50.00    59.94
   1680x1050     59.88
   1600x900      60.00
   1280x1024     75.02    60.02
   1152x864      75.00
   1280x720      60.00    50.00    59.94
   1024x768      75.08    60.00
   800x600       75.00    60.32
   720x576       50.00
   720x480       60.00    59.94
   640x480       75.00    60.00    59.94
   720x400       70.08
   2560x1080_40.00  39.93*
 DVI-0 disconnected (normal left inverted right x axis y axis)
 VGA-0 disconnected (normal left inverted right x axis y axis)
That's what I put into the 10-monitor.config file
Section "Monitor"
  Identifier "Monitor0"
EndSection
Section "Screen"
  Identifier "Screen0"
  Device "HDMI-0"
  Monitor "Monitor0"
  DefaultDepth 24
  SubSection "Display"
    Depth 24
    Modes "2560x1080_40.00"
  EndSubSection
EndSection
sscheuss
