I use this command everytime I login because the screen is just too bright.
xrandr --output HDMI-A-0 --brightness 0.90
How can I make this command run on startup? I use Kubuntu 19.10.
Thanks.
muru
  • 207,228
you should create a file named rc.local in /etc folder and give it executable permissions...
sudo nano /etc/rc.local
file needs to be look like this
#!/bin/bash
use Ctrl+x to save and exit click Y Enter to confirm ...
Note:
xrandr --output HDMI-A-0 --brightness 0.90 --gamma 1.05:1.00:0.95
also works to adjust color using R:G:B channels and a little bit sharpness when you combine with --gamma I think ...
for better contrast I use this :
xrandr --output DVI-D-0 --brightness 1.1 --gamma 0.9:0.9:0.9
for more cold colors :
xrandr --output HDMI-A-0 --brightness 1.1 --gamma 0.85:0.85:0.9
