123
I was playing around with some settings, and now I need to reset GNOME to it's defaults - how do I do that?
jrg
  • 61,707
9 Answers9
133
For Unity-related configuration resetting, take a look here.
For Ubuntu 17.10 and higher, you can reset all the settings using dconf.
This command will delete your configuration files. Once it's run there is no going back!
Still with me?
GNOME 2
Run the following on a terminal or with Alt+F2:
rm -rf .gnome .gnome2 .gconf .gconfd .metacity
That will remove all the GNOME 2 configuration settings. Log out, and log back in. You'll be back to a stock desktop.
You can backup before playing around with your settings in the future:
mkdir ./.old-gnome-config && mv ./.gnome* ./.old-gnome-config && mv .gconf* ./.old-gnome-config && mv ./.metacity ./.old-gnome-config
GNOME 3
If your config isn't worth saving run the following:
rm -rf .gnome .gnome2 .gconf .gconfd .metacity .cache .dbus .dmrc .mission-control .thumbnails ~/.config/dconf/user ~.compiz*
To back up and reset GNOME3:
mkdir ./.old-gnome-config/ && mv ./.gnome* ./.old-gnome-config/ && mv .gconf* ./.old-gnome-config/ && mv ./.metacity ./.old-gnome-config/ && mv ./.cache ./.old-gnome-config/ && mv ./.dbus ./.old-gnome-config/ && mv ./.dmrc ./.old-gnome-config/ && mv ./.mission-control ./.old-gnome-config/ && mv ./.thumbnails ./.old-gnome-config/   && mv ~/.config/dconf/* ./.old-gnome-config/
Pablo Bianchi
  • 17,371
jrg
  • 61,707
30
For 17.10+
There isn't a great solution but this may do the job or most of it.
dconf reset -f /org/gnome/
Then log out/in
That command's path could be shortened if needing a more extensive reset, i.e. to just /org/ or even / but I'd go with above first.
Worst case one could also just go this in a terminal, I think it's a bit overkill as it will set all dconf (gsettings) back to defaults
mv .config/dconf/user .config/dconf/user.bak && sudo reboot
muru
  • 207,228
doug
  • 17,212
21
Fore me those directories were not sufficient - I had to delete ~/.config/dconf/user as well.
This helped for me in those two cases:
  • gnome-panel config broken (tried to specify location "left" for one gnome panel, it immediately crashed and could not be started afterwards)
  • GTK Theme and GTK Icons broken (nevertheless the selection via e. g. gnome-tweak-tool, it remained in ugly Windows-style grey look and icons were standard gnome - I have no clue how this was provoked, it appeared suddenly after login)
This corresponds to the Gnome 3 Fallback Mode I use on Linux Mint 12 Lisa (Oneiric based). But the GTK problem persisted in all other login modes as well (MATE, Gnome 3 Standard)!
I am unsure now to which mechanism the ~/.config/dconf/user file corresponds, as I found out that in Linux Mint only _mateconf-editor_ is installed by default but outfitted with the title and icon of gconf-editor from Natty! After installing gconf-editor additionally, this one is titled identically but has a different (new) icon. But don't rely on this icon stories, because this will rely on the icon theme which is Mint-X-Dark for me.
Theory says that dconf is the successor for gconf, but I found no information regarding the GUIs.
d a i s y
  • 5,551
Nicolas
  • 865
12
If you want to reset your GNOME specific settings to default as if you had never logged in try
Logout, switch to command line (Alt + Ctrl + F4), login, do:
Switch to X (Alt + Ctrl + F2, F7 on older versions).
Just like they described it here.
Pablo Bianchi
  • 17,371
Resetting Gnome Extensions
If you need to remove your Gnome Extensions (I ran into this problem when trying out Ubuntu 17.10 on an upgraded system) run:
rm -rf ~/.local/share/gnome-shell/extensions
Keep in mind that this will wipe all of your extensions.
To remove an individual extension, you can navigate to ~/.local/share/gnome-shell/extensions and look for the extension's folder, then delete it.
If you'd like to backup
To backup, run:
cp ~/.local/share/gnome-shell/extensions ~/.local/share/gnome-shell/extensions-bkup
muru
  • 207,228
RolandiXor
  • 51,797
You can use the mv command.
The syntax is:
mv source1 source2 source3 ... sourceN destination
In your case:
cd ~
mkdir .old-gnome-config
mv .gnome .gnome2 .gconf .gconfd .metacity .cache \
.dbus .dmrc .mission-control .thumbnails .config/dconf/user \
.compiz* .old-gnome-config/
The last one is a directory and it's the destination.
maxadamo
  • 162
-1
Reinstalling gnome-tweak-tool resolved this issue and after reboot the GNOME 3 come up again. Actually gnome-tweak-tool was installed but the system detects it as a uninstalled one.
Eliah Kagan
  • 119,640
askkur
I did :
cd $HOME
cd .config
rm -R *
sudo reboot
And I've found my desktop like the first day I create my user account, but all my software params are the same (firefox, thunderbird, filezilla...)
amc
  • 7,292
