16
Possible Duplicate:
How do I reset my Unity configuration?
How do I reset GNOME to the defaults?
Apparently I've messed up a lot with my Unity and Gnome 3 settings and now my system looks ugly, and even if I made changes (using gnome-tweak-tool for example) to my configuration nothing seems to work. Can you guys tell me how to delete all the Unity and Gnome related settings (like also compiz and all other similar ones) and restart with the settings of an installation from scratch??
I'd really appreciate your help, thanks a lot guys!
lucacerone
  • 1,721
This worked for me! I've just reset a broken Unity desktop where my user's theme had turned ugly and the dash and top left tray and system menu had stopped appearing. None of the apps seemed to be broken, it was only the very desktop environment I wanted to reset. I did this by moving these two directories out of the way: ~/.config/compiz and ~/.config/dconf. Before I reached to this conclusion, I had run "unity --reset" and "unity --reset-icons", but as far as I could tell, they didn't influence my setup one bit.
Instructions:
  1. Log out of X. I can't do this, since my logout menu didn't appears.
  2. Find a virtual terminal (press Ctrl+Alt+F1) and login.
  3. Kill X if you can't logout:
    sudo killall Xorg
    X will die, restart, and switch virtual terminal. Switch back with Ctrl+Alt+F1.
  4. Then run:
    mv -v ~/.config/compiz-1 ~/.config/compiz-1.BROKEN
    mv -v ~/.config/dconf ~/.config/dconf.BROKEN
  5. Then go back to X (Ctrl+Alt+F7) and login.
You should now have been set back to a working Unity desktop environment, but without resetting any of your application settings. Also, you can restore the directories, if you wish, since they where just renamed and not deleted.
Zta
  • 323
  1. If you want to reset Unity (this will only reset the Unity settings in CompizConfig Settings Manager and leave the other CCSM settings intact), open a terminal (or press ALT + F2) and enter:
    unity --reset
  2. If you want to reset the Unity Launcher icons (dock bar on the left) to their initial state, run the following command:
    unity --reset-icons
enzotib
  • 96,093
mac
  • 4,001
Try these three commands:
gconftool-2 --recursive-unset /apps/compiz-1
<p>unity --reset &amp;</p>
<p>rm -rf .gnome .gnome2 .gconf .gcond .metacity</p>
Then, restart PC
NEXT TIME: install 'Ubuntu Tweak', and backup your desktop settings
sudo add-apt-repository ppa:tualatrix/next
<p>sudo apt-get update</p>
<p>sudo apt-get install ubuntu-tweak  [0.6 beta, Oneiric capable]</p>
<p>sudo apt-get install ubuntu-tweak-0  [old version]</p>
david6
  • 14,528
  • 38
  • 46
You can try and identify where the config files that are causing problems are by creating a new user in user accounts. Now if you log into the new user you have created and everything looks fine then you must still have bad settings in your home directory.
You can try moving hidden config folders until you find the one containing the unity/gnome settings.
If your settings are still wrong for the new user then system level config files have been changed, to remove these changes use:
sudo apt-get -o DPkg::options::=--force-confnew --reinstall install <package>
This will force dpkg to replace modified config files with the original ones losing all post install customizations. Check man dpkg for more details
