61
For the command
sudo apt-get update
I get following error:
W: Failed to fetch http://ch.archive.ubuntu.com/ubuntu/dists/maverick-updates/multiverse/binary-i386/Packages.gz
407  Proxy Authentication Required (The ISA Server requires authorization to fulfill the request. Access to the Web Proxy filter is denied. )
I am running Ubuntu 10.10 installed on Windows XP using VirtualBox. For Internet connections I am using proxy server with an authentication. I tried to use gnome-network-proxy tool to set proxy settings system-wide.
After that /etc/environment has been updated by http_proxy variable with the format http://my_proxy:port/, there were no authentication data.
I checked this with Firefox. Browser asked my for login and password and everything was working fine. It was unfortunately not the case for apt-get. I have also tried to do as described here. Unfortunately it does not work.
May it be somehow related to the fact that a proxy is in a Windows domain, any ideas?
My proxy name is http-proxy. Is '-' a special character here?
tommyk
  • 4,556
12 Answers12
61
For my corporate network I was given by my administrator the proxy name in the format:
http://[username]:[password]@[proxy-webaddress]:[port]
For our Windows network our username is in the format:
[domain]\[username]
For example:
http://mywindowsdomain\fossfreedom:password@askubuntu-proxy.com:8080
This was added to the following NEW file (it doesnt exist by default):
gksudo gedit /etc/apt/apt.conf.d/01proxy
The following text was added:
Acquire::http::Proxy "http://mywindowsdomain\fossfreedom:password@askubuntu-proxy.com:8080";
If you are using an anonymous proxy then you don't need your login credentials:
Acquire::http::Proxy "http://askubuntu-proxy.com:8080";
Save the file and then checked that all was ok with:
sudo apt-get update
Braiam
  • 69,112
fossfreedom
  • 174,526
13
I have found that USERNAME and PASSWORD entered into the "Network Proxy" applet does not get stored into the apt.conf file you must manually add the username and password in the /etc/apt/apt.conf file.
The "Network Proxy" applet only stores the hostname and the port.
The basic syntax is
Acquire::http::proxy "http://User:Password@host:port/";
Acquire::ftp::proxy "ftp://User:Password@host:port/";
Acquire::https::proxy "https://User:Password@host:port/";
If you are using Windows usernames and password follow this advice:
User = Domain/Username
(windows users use / not \)
If you are using Windows strong/complex password with special characters you must use the URL encoding for the values, for example an "@" in the password would be "%40".
fossfreedom
  • 174,526
MneMoth
  • 131
Try setting http_proxy to http://user:pass@proxyserver:port/
edit:
If setting http_proxy does not work try editing apt.conf. In
Ubuntu apt.conf is fragmented in /etc/apt/apt.conf.d/ directory.
In this directory edit /etc/apt/apt.conf.d/01ubuntu:
APT {
    Acquire {
        http {
            Proxy "http://user:password@server:port";
or try setting it using Synaptic: Settings -> Preferences -> Network
And then set your proxy settings in "Manual proxy configuration".
I'm behind a MS ISA proxy and I'm using Cntlm Authentication Proxy; in the apt.conf I have 4 lines; I've read somewhere that the last line must be empty, but I'm not sure about it. It works perfectly:
Acquire::http::proxy "http://127.0.0.1:3128/";
Acquire::ftp::proxy "ftp://127.0.0.1:3128/";
Acquire::https::proxy "https://127.0.0.1:3128/";
kos
  • 41,268
dEvil
  • 51
cntlm has a discovery option that helps find the right config to work with the NTLM auth of your network, try this:
cntlm -I -M http://test.com
copy and paste the results in /etc/cntlm.conf
restart cntlm
Jorge Castro
  • 73,717
tommyk
  • 4,556
This one has been working for me!!
(adding proxy manually from the GUI via system-settings->network etc should work) But if doesn't and you export env variable from the terminal:
export http_proxy=http://<your proxy url>:<proxy port>
and again for https:
export https_proxy= <usually the same as the http>
Most important to add the -E: To run sudo apt-get install or sudo apt-get update you must run:
sudo -E <command>
The "-E" use your user environment variables for the root (sudo) , for that matter the http_proxy/https_proxy you've just exported.
Hope it helps :)
Kohn1001
  • 131
  1. Open terminal and add the following lines to /etc/apt/apt.conf.
    gksu gedit /etc/apt/apt.conf
  2. Add these 2 lines:
    Acquire::http::Proxy "http://user:pass@proxy-host:port/";
    Acquire::ftp::Proxy "http://user:pass@proxy-host:port/";
  3. Save and exit.
    Now apt-get update and should work behind a proxy, but you will notice that still something is not working, that is the add-apt-repository command.
    To be able to add repository behind a proxy, type the following commands:
    # export https_proxy="http://192.168.1.5:8080"
    # sed -i 's/"keyserver.ubuntu.com"/"hkp://keyserver.ubuntu.com:80"/' /usr/share`/pyshared/softwareproperties/ppa.py`
    Now you can add repositories in Lucid and Natty using LANG=C add-apt-repository
    Example:
    root@ubuntu:~# LANG=C add-apt-repository ppa:motumedia/mplayer-daily
Via Unixmen
Peachy
  • 7,235
  • 40
  • 47
How to apply apt-get update or install in Ubuntu ? I was behind a proxy server and after installing Ubuntu i coulden`t update or install anything using the apt-get command. After searching i found that The apt package has been changed, now there is no more apt.conf on /etc/apt directory.
What i did to resolve this issue is the follow :
Open terminal and the file
sudo -H gedit /etc/bash.bashrc
and add at the bottom of the file these 2 lines :
#proxy
export http_proxy=http://user:password@host:port/
export ftp_proxy=http://user:pass@host:port/
Now save and exit, Now you will be able to update, upgrade or install packages in Ubuntu
muru
  • 207,228
hhlp
  • 42,872
Had this same issue after installing Ubuntu 18.04. What worked for me was to:
  1. Open Network Proxy screen in Network settings
  2. Select Manual and adding both http and https proxy info
  3. Additionally set Ignore Hosts field with:
    https://extensions.gnome.org*, *.extensions.gnome.org*
  4. Restarted Ubuntu
As for point 3, not sure if adding the above entry works or not but this step works for me
abu_bua
  • 11,313
Vuzi
With a BlueCoat proxy, for me the format of the apt.conf file was required to look like:
Acquire::http::proxy "http://Domain%5cUserID:Password@proxy.name.whatever:80/";
Acquire::ftp::proxy "ftp://Domain%5cUserID:Password@proxy.name.whatever:80/";
Acquire::https::proxy "https://Domain%5cUserID:Password@proxy.name.whatever:80/";
^ ^ ^ ^ Blank line after 3rd proxy line, do not enter this line. ^ ^ ^ ^
Peachy
  • 7,235
  • 40
  • 47
Jason
This one-liner solution worked for me:
sudo env http_proxy=http://<ip>:<port> apt-get update
Raheel
  • 111
  1. Start Synaptic (go to System -> Administration -> Synaptic in Gnome 2, or type "synaptic" in the Dash in Unity).
  2. On the menu bar, click Settings, followed by Preferences.
  3. When the Preferences window appears, click on the Network tab.
  4. Select the Manual proxy configuration radio button and enter your proxy information.
  5. To apply authentication information, click the Authentication button and enter username and password.
  6. Click OK to close the HTTP Authentication window.
  7. Click OK to close the Preferences window.
  8. Click the Reload button to update the package lists.
Note that this setting change will also affect the Update Manager.
