I was trying to update my Ubuntu 14.04 system using terminal but I got this result
W: Failed to fetch http://in.archive.ubuntu.com/ubuntu/dists/trusty-backports/restricted/binary-i386/Packages  407  Proxy Authentication Required
Also in the top-right corner of my PC there is a red triangle which says the update information is outdated. Again when I tried to download something from software repository there comes a window which says untrusted package ,then when I select ok then another window pops out which says check your Internet connection. But I am well connected to the Internet(under proxy network),so what should I do?
Anislein
  • 101
Try this:
In a terminal, run this command: sudo apt-get update
Then run this command: sudo apt-get autoclean
Then run this command: sudo apt full-upgrade
If that doesn't work, a fresh install may be easier than extensive troubleshooting, after backing up your personal data.
I hope this helps.
RCline7
RCline7
  • 536
