I am trying to install a package python-pygments under Ubuntu. After launching sudo apt-get install python-pygments, it is blocked:
Reading package lists... Done
Building dependency tree
Suggested packages:
  ttf-bitstream-vera
The following NEW packages will be installed:
  python-pygments
0 upgraded, 1 newly installed, 0 to remove and 43 not upgraded.
Need to get 347 kB of archives.
After this operation, 2,527 kB of additional disk space will be used.
0% [Connecting to cache.polytechnique.fr (129.104.38.6)]
cache.polytechnique.fr in the line line is the proxy of my school. A download in the campus should work, but the problem is that I am physically not in the campus. I try to remove proxy setting via Chromium (the method of network proxy: NONE), it still drives to cache.polytechnique.fr, does anyone know how to let sudo avoid this proxy?
Portablejim
  • 2,768
SoftTimur
  • 3,089
You probably set the proxy settings globally, so that they applied to all applications, including apt-get.
When you turn off the proxy settings, click the button that says "Apply system wide" (or something like that). It will prompt you for your password. Now you need to restart Terminal in order to have the settings applied.
If that does not solve the issue, see if /etc/apt/apt.conf exists. This can be done with:
cat /etc/apt/apt.conf
If the file exists (if you see some output), open it up. This can be done with:
gksudo gedit /etc/apt/apt.conf
If the file contains a line with Acquire::http::Proxy in it, delete the line, or put a # in front of the line. Save the file and exit the text editor.
Try sudo apt-get command again.
Alaa Ali
  • 32,213
Portablejim
  • 2,768
You can add following line in /etc/apt/apt.conf:
Acquire::http::proxy DIRECT;
Eliah Kagan
  • 119,640
amol
