51
Possible Duplicate:
apt-get does not work with proxy
I have tried changing my proxy settings in a terminal as:
export HTTP_PROXY=http://10.1.3.1:8080
and
export http_proxy=http://10.1.3.1:8080
but when I try to install a new package or update apt-get, apt-get starts displaying messages from which it seems it is trying to connect to a previously set proxy:
sudo apt-get update
0% [Connecting to 10.1.2.2 (10.1.2.2)] [Connecting to 10.1.2.2 (10.1.2.2)
I have tried setting the proxy via bashrc file but that din work either. As far as I remember 10.1.2.2 was set using GNOME GUI but I don't have access to the GUI right now so I am trying to set it from terminal.
Uthman
  • 1,528
Okay just solved it. Adding following line to /etc/apt/apt.conf has solved the problem: Acquire::http::proxy "http://10.1.3.1:8080/";
If file does not exist, create it. Do not confuse it with apt.conf.d directory.
Uthman
  • 1,528
63
The file:
/etc/environment
Is the correct place to specify system-wide environment variables that should be available to all processes. See https://help.ubuntu.com/community/EnvironmentVariables for details. Note that this is not a script file but a configuration file.
If you want this for the specified command only, use (as root):
http_proxy=http://10.1.3.1:8080 apt-get update
13
Edit your:
gedit /etc/profile
Enter the details in this format.
export http_proxy=http://username:password@proxyhost:port/
export ftp_proxy=http://username:password@proxyhost:port/
Then run the
sudo apt-get update
That should do it for you.
As stated above you can enter the proxy into apt.conf (Piyush Credit)
muru
  • 207,228
LinuxBill
  • 2,107
