I have installed 13.04 (64bit) and after not having any wired internet, did a fresh install with 12.04 (64bit). The machine was previously running Windows 7 with wired connection working fine. A wierd issue is that normal Google searches (even images!) work from Firefox. Clicking on any links fails, however.
I cannot paste terminal outputs as I only have wired access from the Ubuntu machine.
uname -r shows that the kernel is: 3.8.0-29-generic.
ifconfig shows that eth0 has an inet address (129.11.224.156)
Pinging google.com or 173.194.70.101 gives the following result:
PING www.google.com (173.194.70.101) 56(84) bytes of data
4 packets transmitted, 0 received, 100% packet loss, time 3023ms
Pinging the router is successful:
4 packets transmitted, 4 received, 0% packet loss, time 3000ms
dmesg gives the following output for eth0:
tg3 0000:02:00.0 eth0: Link is up at 100 Mbps, full duplex
tg3 0000:02:00.0 eth0: Flow control is off for TX and off for RX
Let me know if I need to provide more information.
Thanks!
Update 1:
Output for sudo lshw -class network:
Network
Description: Ethernet interface
product: Netlink BCM5784M Gigabit Ethernet PCIe
vendor: Broadcom Corp
physical id: 0
bus info pci@0000:02:00.0
local name: eth0
version: 10
serial 00:23:ae:65:31:ce
capacity: 1Gbit/s
width: 64bits
clock: 33MHz
Output for route -n
Kernel IP routing table
Destination, Gateway, Genmask, Flags, Metric, Ref, Iface
0.0.0.0, 129.11.224.103, 0.0.0.0, UG, 100, 0, eth0
192.11.224.0, 0.0.0.0, 255.255.255.0, U, 0, 0, eth0
169.254.0.0, 0.0.0.0, 255.255.0.0, U, 1000, 0, eth0
Update 2:
Changing the mtu to 1472 and restarting the network did not have any effect
Here is the output for cat /etc/network/interfaces:
auto lo
iface lo inet loopback
Update 3:
Ok so apparently I need to go through a proxy server. I have followed instructions given here:
How to Configure Ubuntu desktop to use your proxy server
This has been successful in enabling fullinternet access. I have set proxies following a few instructions here.
Thank you for the help!
