I am using Ubuntu WSL on Windows 10. How to configure HTTP proxy with authentication on it?
cntlm proxy for NTLM authentication
I am assuming your proxy requires a NTLM based user authentication, which will not work with the credentials specified in $HTTP_PROXY. A NTLM capable proxy this required for that: e.g. cntlm.
Install cntlm proxy
The default way of installing the proxy would be to use sudo apt-get install cntlm, but without any proxy this will obviously fail. You need to manually download the package cntlm_0.92.3-1ubuntu2_amd64.deb and copy it into your WSL instance.
Install the package with
$ sudo dpkg -i cntlm_0.92.3-1ubuntu2_amd64.deb
Configure cntlm proxy
The cntlm proxy requires proper NTLM-Proxy configuration in /etc/cntlm.conf:
# /etc/cntlm.con
Domain Domain
Username username
Proxy 1.2.3.4:5678
NoProxy localhost, 127.0.0.*, 10.*, 192.168.*
Listen 3128
This is the minimal required configuration for cntlm. Test and verify cntlm with the following command:
$ cntlm -M http://www.google.com
cntlm: Starting cntlm version 0.92.3 for LITTLE endian
cntlm: Proxy listening on 127.0.0.1:3128
cntlm: Workstation name used: hostname
Password:
If the authentication is successful, generate hashes for the authentication by using the -H switch:
$ cntlm -H
cntlm: Workstation name used: somehost
cntlm: Using following NTLM hashes: NTLMv2(1) NT(0) LM(0)
Password:
PassLM 123456789ABCDEF123456789ABCDEF12
PassNT 123456789ABCDEF123456789ABCDEF12
PassNTLMv2 123456789ABCDEF123456789ABCDEF12 # Only for user 'username', domain 'Domain'
cntlm: Terminating with 0 active threads
Add the three hashes PassLM, PassNT and PassNTLMv2 to the cntlm configuration file /etc/cntlm.conf. Then activate the proxy via systemd:
$ sudo systemctl restart cntlm
Now the proxy should listen on your localhost at port 3128.
Configure proxy
Now you can configure the proxy as described in this post but use:
$ export http_proxy=http://localhost:3128/
$ export https_proxy=http://localhost:3128/
- 4,111
From your bash shell:
export http_proxy=http://[username]:[password]@[proxy-webaddress]:[port]
and possibly
export https_proxy=https://[username]:[password]@[proxy-webaddress]:[port]
Username and password are often Windows domain credentials. If the password contains any special characters, you may need to escape the special characters with a backslash to protect them from the shell. For example, if your Windows account is "gomer" with a password of "Pea$1rzz", and your proxy server is bluecoat.acme.com on port 8080, then you would say
export http_proxy=http://gomer:Pea\$1rzz@bluecoat.acme.com:8080
export https_proxy=https://gomer:Pea\$1rzz@bluecoat.acme.com:8080
echo $http_proxy
echo $https_proxy
should show the correct credentials. You'll need to do this for each shell. So, if you're wanting to do some work with apt, it may be more convenient to open a root shell
sudo bash
before setting your proxies.
- 79
