I am trying to set proxy server using gksudo gedit /etc/apt/apt.conf
and trying to add the commands as in 'apt-get' does not work with Proxy
Acquire::http::Proxy "http://user:pass@proxy-host:port/";
Acquire::ftp::Proxy "http://user:pass@proxy-host:port/";
When I tried this a message on terminal occurs
/usr/share/themes/Ambiance/gtk-2.0/apps/mate-panel.rc:30: error: invalid string constant "murrine-scrollbar", expected valid string constant
Error copying '/home/dipesh/.Xauthority' to '/tmp/libgksu-FU5d7j': No such file or directory
with a message on screen
Failed to run gedit '/etc/apt/apt.conf' as user root.
Unable to copy the user's Xauthorization file.
when I manually try to add in apt.conf file, it denies messaging
You do not have the permissions necessary to save the file. Please check that you typed the location correctly and try again.
When I tried this it works
sudo env http_proxy=http://<ip>:<port> apt-get update
But sudo apt-get update or
sudo add-apt-repository ppa:webupd8team/sublime-text-3 or
sudo env http_proxy=http://10.7.0.1:8080 apt-repository ppa:webupd8team/sublime-text-3
doesn't works.
I am new to Ubuntu please help!
