Im having serious problems after installing Ubuntu 13.10. I cannot access my network settings under system settings. Whenever i try to access network settings, the settings app crashes off. This is the output it produces when i run it from the terminal :
kelvine@kelvinelove:~$ sudo gnome-control-center
[sudo] password for kelvine:
(gnome-control-center:4595): IBUS-WARNING **: The owner of /home/kelvine/.config/ibus/bus is not root!
network-cc-panel:ERROR:rfkill-glib.c:83:type_to_string: code should not be reached
How can i resolve this error??
kelvinelove
  • 1,619
You can't start gnome-control-center as root. Start it normally and the error will go away.
Donarsson
  • 2,749
