57
Last night I was trying to burn CDs. Being annoyed with k3b and choosing to use brasero instead, I went to remove k3b.
I typed in:
sudo apt-get remove k3b
I hit tab twice and saw that I had both k3b and k3b-data on my system. Assuming that I wouldn't need k3b-data on my system without k3b, I wanted to remove it as well so I typed in:
sudo apt-get remove k3b*
Unfortunately I hit Y to confirm without looking. It uninstalled a whole lot more than k3b and k3b-data. It uninstalled packages which did not fit my k3b* regex. For example: transmission and network-manager.
I'm fairly certain that I didn't have a space between k3b and * but I don't know why else it would remove all that it did. Is there something about apt-get that I'm misunderstanding?
Eliah Kagan
  • 119,640
6 Answers6
72
The command you want is sudo apt-get remove '^k3b.*', because:
  • You need .* to match any character, any number of times
  • You need ^ to match the start of the string
  • You need to quote the regex to prevent bash from interpreting * as a wildcard
(This answer completes and summarizes previous info provided by qbi and Flimm)
Boris Dalstein
  • 880
The regular expression * stands for zero or arbitrarily many. So you told apt-get to remove anything which contains k3 followed by any number of b, so basically everything which contains k3. If I try your command on my system it wants to remove 58 packages.
sudo apt-get remove -s k3b*
Package k3b is not installed, so not removed
Package k3b-data is not installed, so not removed
Package k3b-dbg is not installed, so not removed
Package libcanberra-gtk3-0 is not installed, so not removed
Package libcanberra-gtk3-0-dbg is not installed, so not removed
Package libcanberra-gtk3-dev is not installed, so not removed
The following packages will be REMOVED:
  appmenu-gtk ardour audacity brasero brasero-cdrkit firefox-globalmenu
  gconf-editor gir1.2-appindicator-0.1 gnome-applets gnome-control-center
0 upgraded, 2 newly installed, 58 to remove and 0 not upgraded.
Eliah Kagan
  • 119,640
qbi
  • 19,515
13
Use sudo apt-get remove ^k3b instead. When you install or remove packages, * is often dangerous and rarely needed. If you do use *, you should quote it, but that does not make it safer, because its tendency to select far more packages than you intend is the result of the way apt and apt-get interpret it and not an effect of pathname expansion.
  • Even safe uses of * are often unnecessary.
  • Unsafe uses are brutal. Removing k3b* removes every package that contains k3 anywhere in its name (and every package that depends on such a package). That's not a typo--containing k3 is sufficient, even without the b, because b* means "zero or more bs."
When you run apt or apt-get with the install, remove, or purge action, each subsequent argument is first1 interpreted as the name of an individual package. If a package with that exact name exists, the action is performed for it.
If there is no such package, apt and apt-get will check if the argument contains any of the common regular expression metacharacters2 ., ?, +, *, |, \[, ^, or $. If not, it's done--no package was found.
If it does contain any of those characters, then it is treated as a regular expression and matched against any part of any package name. It doesn't have to match the whole name. As others have said, * in a regular expression doesn't mean the same thing as * in a glob. ? doesn't either. In a regular expression:
  • * allows the previous item to appear any number of times--including just once or not at all--instead of exactly once.
  • ? makes the previous item optional--that is, it allows it to appear zero or one times.
apt-get(8) (man apt-get) says:
If no package matches the given expression and the expression contains one of '.', '?' or '*' then it is assumed to be a POSIX regular expression, and it is applied to all package names in the database. Any matches are then installed (or removed). Note that matching is done by substring so 'lo.*' matches 'how-lo' and 'lowest'. If this is undesired, anchor the regular expression with a '^' or '$' character, or create a more specific regular expression.
The manpage only mentions ., ?, and *, but it is incomplete, as +, |, [, ^, and $ are also sufficient to let apt-get or apt interpret the pattern as a regular expression.3
Although you can match any number of any characters with .*--not just *--you only need this if it would appear in the middle of your regular expression. Because the pattern is matched against any substring of a package name, it's pointless at the end (or beginning) of the pattern.
The manpage mentions ^ and $. These (especially ^) are key to writing safe, efficient patterns for use with the install, remove, or purge actions in apt or apt-get.
  • ^ anchors a regular expression to the beginning of the whole string. ^k3b selects all packages whose names start with k3b.
  • $ anchors a regular expression to the end of the whole string. k3b$ would select all packages whose names end with k3b.
Therefore you can use this command to safely remove the packages:
Finally, in the specific case you mentioned, you might as well just pass both names yourself:
sudo apt-get remove k3b k3b-data
Then you avoid all this complexity! (Though anchoring with ^ is simple once you're used to it.) Or use brace expansion, which your shell expands into the above command:
sudo apt-get remove k3b{,-data}
1 There are two exceptions to this: (a) some options (e.g., -f, --purge) are recognized, and (b) some punctuation characters appearing at the end of an argument that would otherwise be taken as a package name to perform the action can be used to alter what is done (e.g., sudo apt install ubuntu-desktop^ installs the task rather than the package, and when ^ appears at the end ).
2 Other regular expression metacharacters exist. For example, \ is supported by all dialects of regular expressions and commonly used. ., ?, +, *, |, [, ^, and $ just happen to be the metacharacters the APT developers decided would trigger interpretation as a regular expression (after resolution as an exact package named has failed).
3 The easiest way to verify this is to simulate installation or removal with such a pattern, using the -s option as described above. For example, running apt -s install ^virtualbox shows that sudo apt install ^virtualbox would have the effect of attempting to install every package the package manager knows about whose name begins with virtualbox. However, this behavior can also be verified by examining the source code. Check the CacheSetHelper::PackageFromRegEx function in cacheset.cc.
Rinzwind
  • 309,379
Eliah Kagan
  • 119,640
Use .* instead of *, and put inside quotes ' '
sudo apt-get remove 'k3b.*'
Thach Van
  • 111
You can use apt search which has the advantage of searching in both package names and package descriptions But it is also a bit dangerous. for example, if you want to remove any package related to MY_PATTERN you can run:
sudo apt search MY_PATTERN | grep "^[^\ ]*/" -o | sed 's/\///' | xargs -I '{}' sudo apt remove -y '{}'
BE CAUTIOUS: Don't use small search patterns that can be found in many words like he, and,.... it might cause non-related package removal and therefore corruption. Before run check out the output of the apt search MY_PATTERN first.
apt search MY_PATTERN: Find the pattern in the package names and package descriptions on the remote repositories.
grep "^[^\ ]*/" -o: extract the package name.
sed 's/\///': remove / from the extracted names.
xargs -I '{}' sudo apt remove -y '{}': remove one by one.
aminag
You more then likely remove a lib that had k3b in it that those programs depended on.
In short you may never know. I recommend not using a wildcard to remove things and to read things when prompted (sorry).
Also with out the -n regex searches use all fields and not just names
http://ccrma.stanford.edu/planetccrma/man/man8/apt-cache.8.html
also qbi is correct your regex is flawed from the get-go
coteyr
  • 18,724
