I am currently installing php7.0 and was wondering if there is an shorter way to install the modules. normally I type:
    apt-get install php7.0 php7.0-fpm php7.0-mbstring php7.0-mcrypt
     php7.0-phpdbg php7.0-dev php7.0-curl php7.0-sqlite3 php7.0-json
     php7.0-gd php7.0-cli
Is there an regular expression so you don't have to type php7.0 over and over again? Something like:
   apt-get install php7.0-{fpm mbstring mcrypt phpdbg dev curl sqlite3
    json gd cli}
I searched for something like this for hours but could not find it. In advance thanks for your reply.
As @Videonauth suggested, you can use apt-get install php7.* but that will install all packages whose names contain php7. To install those whose names starts with php7, use apt-get install '^php7. *. To instal only those on your list, you can use brace expansion. The format is almost what you already tried: braces but a comma-separated list:
$ echo foo{a,b,c}
fooa foob fooc
Therefore:
$ echo php7.0-{fpm,mbstring,mcrypt,phpdbg,dev,curl,sqlite3,json,gd,cli}
php7.0-fpm php7.0-mbstring php7.0-mcrypt php7.0-phpdbg php7.0-dev php7.0-curl php7.0-sqlite3 php7.0-json php7.0-gd php7.0-cli
So, you could run:
sudo apt-get install php7.0-{fpm,mbstring,mcrypt,phpdbg,dev,curl,sqlite3,json,gd,cli}
terdon
  • 104,119
