18
Seeing that there was a new VirtualBox release, I tried to install it on Kubuntu 15.04...
However, now all of my VBox 4.3 packages in the ubuntu repositories are broken (Virtualbox is provided by Virtualbox-5.0 which is not installed), and VirtualBox 5.0 won't work as it says DKMS is broken:
Uninstalling old VirtualBox DKMS kernel modules/etc/init.d/vboxdrv: 302: /etc/init.d/vboxdrv: /usr/share/virtualbox/src/vboxhost/do_dkms: not found
 ...done.
Trying to register the VirtualBox kernel modules using DKMS/etc/init.d/vboxdrv: 327: /etc/init.d/vboxdrv: /usr/share/virtualbox/src/vboxhost/do_dkms: not found
 ...failed!
  (Failed, trying without DKMS)
Reinstalling virtualbox-dkms:
dpkg: error processing package virtualbox-dkms (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of virtualbox-qt:
 virtualbox-qt depends on virtualbox (= 4.3.26-dfsg-2ubuntu2); however:
  Package virtualbox is not configured yet.
  Package virtualbox-5.0 which provides virtualbox is not installed.
dpkg: error processing package virtualbox-qt (--configure):
No apport report written because the error message indicates it's a follow-up error from a previous failure.
Even though VirtualBox 5.0 was installed via deb package from the Oracle website.
What can I do to either completely remove 5.0 and install VirtualBox 4.3, or correctly install virtualbox 5.0?
I've already tried uninstalling VirtualBox 5.0 (via apt-get purge), then installing 4.3, but get the error relating to VirtualBox being provided by the package virtualbox-5.0.
BnMcG
  • 323
Remove older VirtualBox versions before installing VirtualBox-5.0 !
Uninstall VirtualBox -> sudo apt-get purge "^virtualbox-.*"
Carefully check what will be removed (before you confirm it).
Update the software repositories -> sudo apt-get update
Clean up -> sudo apt-get autoremove && sudo apt-get autoclean && sudo apt-get clean
Download and register the ORACLE public key ->
wget -q -O - https://www.virtualbox.org/download/oracle_vbox.asc | sudo apt-key add -
Add the VirtualBox repo to the software sources ->
echo "deb http://download.virtualbox.org/virtualbox/debian $(lsb_release -sc) contrib" | sudo tee /etc/apt/sources.list.d/oracle-vbox.list
Now update the software repositories again -> sudo apt-get update
Install VirtualBox -> sudo apt-get install dkms virtualbox-5.0
Note for other users who use a newer Ubuntu edition than 15.04 :
As of Ubuntu 16.04 the ORACLE public key to download has changed.
oracle_vbox.asc has to be replaced with oracle_vbox_2016.asc
cl-netbox
  • 31,491
My Virtualbox does not work. It starts but could not execute any of the machines. The solution I found was:
sudo apt-get install virtualbox-dkms
and then:
sudo modprobe vboxdrv
