I did a sudo apt-get remove ruby* and then I saw that some grub packages were being removed too so I went to installed back those packages which log showed to have removed
I set grub to work on my /sda (in general, not any number) when was installing back.
Should all be ok or should I fear for my system and plan installing/reconfiguring more of grub.
And, why did this happpen?
Braiam
  • 69,112
If you don't know exactly what you are doing, you should not use:
sudo apt-get remove package.*
#                          ⤷ or any other character in the place of dot
as this can delete unintended packages and cause more problems than it solves. The package.* will match all packages (and their dependencies) containing the string package in their name. This is from man apt-get, somewhere at the line 110:
       If no package matches the given expression and the expression
       contains one of '.', '?' or '*' then it is assumed to be a POSIX
       regular expression, and it is applied to all package names in the
       database. Any matches are then installed (or removed). Note that
       matching is done by substring so 'lo.*' matches 'how-lo' and
       'lowest'. If this is undesired, anchor the regular expression with
       a '^' or '$' character, or create a more specific regular
       expression.
And this is from Regular Expressions/POSIX Basic Regular Expressions Wikibooks:
* Matches the preceding element zero or more times. For example, ab*c matches "ac", "abc", "abbbc", etc. [xyz]* matches "", "x", "y", "z", "zx", "zyx", "xyzzy", and so on. \(ab\)* matches "", "ab", "abab", "ababab", and so on.
Anyway, if you really want to run something like sudo apt-get remove package.* (or sudo apt-get remove packagey*, or sudo apt-get remove packagec* - all are in this case the same), first run it with -s (--simulate) option to see exactly what it will do (see man apt-get for more info).
Now, I think that you can solve your problem using the following two steps:
  1. Reinstall all the packages that you have removed
  2. Remove only ruby:
    Or, if you want to remove all packages starting their names with ruby:
    sudo apt-get remove ^ruby
    But better to simulate first with:
    apt-get -s remove ^ruby
Radu Rădeanu
  • 174,089
  • 51
  • 332
  • 407
Apt-get works with regular expressions, which means that ruby* selects all packages that contain rub in their name. The correct way to remove all packages starting with ruby is:
Try this command on terminal,
sudo grub-install /dev/sda
It will reinstall grub2 on your disk.
If you want to configure your grub then install grub-pc package.Try the below command to install grub-pc package,
sudo apt-get install grub-pc
Note: Install this package only if you installed Ubuntu in Legacy mode.
Avinash Raj
  • 80,446
