When I do
$ gcc cube.c -lglut -lGL -lGLU -lSDL
/usr/bin/ld: cannot find -lSDL
collect2: error: ld returned 1 exit status
When I do
$ sudo apt-get install libsdl*
Reading package lists...
Building dependency tree...
Reading state information...
libsdl-image1.2 is already the newest version.
libsdl-image1.2 set to manually installed.
libsdl1.2debian is already the newest version.
libsdl1.2debian set to manually installed.
 libsdformat-dev : Depends: libboost-regex-dev but it is not going to be installed
                   Depends: liburdfdom-dev but it is not going to be installed
 libsdl-image1.2-dev : Depends: libtiff-dev
 libsdl-mixer1.2-dev : Depends: libflac-dev (>= 1.2.1) but it is not going to be installed
                       Depends: libvorbis-dev (>= 1.2.0) but it is not going to be installed
 libsdl1.2-dbg : Depends: libsdl1.2debian (= 1.2.15-8ubuntu1) but 1.2.15-8ubuntu1.1 is to be installed
 libsdl1.2-dev : Depends: libsdl1.2debian (= 1.2.15-8ubuntu1) but 1.2.15-8ubuntu1.1 is to be installed
                 Depends: libpulse-dev but it is not going to be installed
 libsdl2-dev : Depends: libpulse-dev but it is not going to be installed
               Depends: libudev-dev but it is not going to be installed
It seems libsdl installation was not successful. While searching about libsdl there are two versions libsdl1 and libsdl2. I am thinking to find some other ways to install them. Anyone have any advice for the installation?
@steeldriver:I did your suggestion and the output was the followings:
$ sudo apt-get update && sudo apt-get upgrade
finished...
$ sudo apt-get install libsdl1.2-dev
Reading package lists... Done
A.B. as you requested. Here is output of commands in your comment.
When I did
$ apt-cache policy libsdl1.2-dev
libsdl1.2-dev:
  Installed: (none)
  Candidate: 1.2.15-8ubuntu1
  Version table:
     1.2.15-8ubuntu1 0
        500 http://ubuntu.mirror.crucial.com.au/ trusty/main amd64 Packages
When I did
$ apt-cache policy libsdl1.2debian
libsdl1.2debian:
  Installed: 1.2.15-8ubuntu1.1
  Candidate: 1.2.15-8ubuntu1.1
  Version table:
 *** 1.2.15-8ubuntu1.1 0
        100 /var/lib/dpkg/status
     1.2.15-8ubuntu1 0
When I did
$ apt-cache policy libpulse-dev
libpulse-dev:
  Installed: (none)
  Candidate: 1:4.0-0ubuntu11
  Version table:
     1:4.0-0ubuntu11 0
A.B.: When I did. Downgrade happened.
$ sudo apt-get install libsdl1.2debian=1.2.15-8ubuntu1
The following packages will be DOWNGRADED:
  libsdl1.2debian
0 upgraded, 0 newly installed, 1 downgraded, 0 to remove and 0 not upgraded.
Need to get 162 kB of archives.
After this operation, 0 B of additional disk space will be used.
Do you want to continue? [Y/n] y
WARNING: The following packages cannot be authenticated!
  libsdl1.2debian
Install these packages without verification? [y/N] y
Get:1 http://ubuntu.mirror.crucial.com.au/ trusty/main libsdl1.2debian amd64 1.2.15-8ubuntu1 [162 kB]
Fetched 162 kB in 0s (243 kB/s)
dpkg: warning: downgrading libsdl1.2debian:amd64 from 1.2.15-8ubuntu1.1 to 1.2.15-8ubuntu1
(Reading database ... 443054 files and directories currently installed.)
Preparing to unpack .../libsdl1.2debian_1.2.15-8ubuntu1_amd64.deb ...
Unpacking libsdl1.2debian:amd64 (1.2.15-8ubuntu1) over (1.2.15-8ubuntu1.1) ...
Setting up libsdl1.2debian:amd64 (1.2.15-8ubuntu1) ...
Processing triggers for libc-bin (2.19-0ubuntu6.6) ...
Solved by doug's suggestion
Open up Software & Updates > Updates tab & make sure that
the first 2 are enabled. (- trusty-security, trusty-updates).
If one or the other wasn't enabled then do so,
after that reload sources & proceed.
Thanks for your solution, doug! Thanks to all who participated in this problem especially steeldriver and A.B.!
Evan S
  • 377
Open up Software & Updates > Updates tab & make sure that the first 2 are enabled. (- trusty-security, trusty-updates). If one or the other wasn't enabled then do so, after that reload sources & proceed.
If both where then try switching severs on main page > Download from: use main server. Then reload sources & see.
You need libsdl1.2-dev (1.2.15-8ubuntu1.1) to be available & it should be, was released in 04/14 - http://packages.ubuntu.com/trusty-updates/libsdl1.2-dev
doug
  • 17,212
-2
Try something like gcc cube.c $(pkg-config --libs glut gl glu sdl). Not totally sure about those package names though.
