I need to remove/ uninstall the list of packages those are found with the grep command.
pratap@PRATAP:~$ sudo apt list --installed | grep plymouth
WARNING: apt does not have a stable CLI interface. Use with caution in scripts.
libplymouth4/bionic-updates,now 0.9.3-1ubuntu7.18.04.1 amd64 [installed]
plymouth/bionic-updates,now 0.9.3-1ubuntu7.18.04.1 amd64 [installed]
plymouth-label/bionic-updates,now 0.9.3-1ubuntu7.18.04.1 amd64 [installed]
plymouth-theme-ubuntu-logo/bionic-updates,now 0.9.3-1ubuntu7.18.04.1 amd64 [installed]
plymouth-theme-ubuntu-text/bionic-updates,now 0.9.3-1ubuntu7.18.04.1 amd64 [installed]
pratap@PRATAP:~$
I want to uninstall the above packages immediately once the above command is executed.
How can I achieve this?
Since you are grep'ing the output of all the installed packages that contain the word plymouth, you can instead pass a regular expression to apt's remove command.
You can run the following command
sudo apt remove 'plymouth.*' --dry-run
This will remove all packages that contain the word plymouth. However, since the command is using a wildcard like that, it might be dangerous and so it's better to review the changes first, hence the --dry-run parameter.
This will allow you to validate what would happen when you run that command, without actually removing anything. If you are satisfied, you can just rerun the same command without the --dry-run parameter.
The following packages will be REMOVED:
  libplymouth4 plymouth plymouth-label plymouth-theme-ubuntu-logo
0 upgraded, 0 newly installed, 5 to remove and 0 not upgraded.
Remv plymouth-theme-ubuntu-text [0.9.3-1ubuntu10]
Remv plymouth-theme-ubuntu-logo [0.9.3-1ubuntu10]
Remv plymouth-label [0.9.3-1ubuntu10]
Remv libplymouth4 [0.9.3-1ubuntu10] [plymouth:amd64 ]
Remv plymouth [0.9.3-1ubuntu10]
Dan
  • 14,180
