22
I used the upgrade manager to upgrade from 17.04 to 17.10. When I start the machine, I only get a black flickering screen now. I was using the nvidia binary drivers before the upgrade.
NOTE: This question (and answer) relate to a specific issue when upgrading from 17.04 to 17.10 while using Nvidia or AMD binary drivers. You might experience a completely different issue. For that please see the more general question My computer boots to a black screen, what options do I have to fix it?.
mniess
  • 10,904
This happened to several users of NVidia or AMD binary drivers (Bug #1705369). You need to re-install the drivers:
  1. Switch to a different terminal (TTY) by pressing CTRL+ALT+F2 and login with your user.
  2. Remove the binary driver by running sudo apt-get purge ^nvidia. AMD users can run amdgpu-pro-uninstall to remove the AMD graphics stack.
  3. If /etc/X11/xorg.conf exists, rename (e.g. sudo mv /etc/X11/xorg.conf{,.bak}).
  4. Disable Wayland completely: edit /etc/gdm3/custom.conf and uncomment the following line # WaylandEnable=false
  5. Reboot Ubuntu with sudo shutdown -r now and you should see the login screen.
You can now install your binary drivers again, either manually (see How do I install the Nvidia drivers) or with the Software Properties GUI. AMD users should refer to the official installation guide for instructions.
After rebooting everything should work as expected.
Note: The new Wayland display server doesn't work with binary drivers, yet, which is why we disabled it in step 4. In the future, when Wayland is fully supported by the binary drivers, you should comment this line again.
mniess
  • 10,904
I had the same problem and reportet a bug already (Bug #1725169). In my case I could locate it to the lowlatency-kernel, that was installed during upgrade without beeing asked. Unfortunately it was the first kernel in grub. Deinstalling this Kernel solved the problem. No need for reinstalling the nvidia-drivers.
mniess
  • 10,904
woko
