So I want to uninstall pidgin. I first ran sudo apt remove pidgin. This worked and something was removed. I then ran apt-cache search pidgin and I got a lot of plugins that were not removed:
pidgin - graphical multi-protocol instant messaging client for X
pidgin-audacious - pidgin integration with Audacious
pidgin-awayonlock - pidgin plugin to set as away on screensaver activation
pidgin-blinklight - Blinks your ThinkPad's ThinkLight upon new messages
pidgin-bot-sentry - pidgin anti spam plugin
pidgin-data - multi-protocol instant messaging client - data files
pidgin-dbg - Debugging symbols for Pidgin
pidgin-dev - multi-protocol instant messaging client - development files
pidgin-encryption - pidgin plugin that provides transparent encryption
pidgin-extprefs - extended preferences plugin for the instant messenger pidgin
pidgin-festival - pidgin plugin to hear incoming messages using voice synthesis
pidgin-gmchess - pidgin integration with gmchess
pidgin-gnome-keyring - integrates pidgin (and libpurple) with the system keyring
pidgin-gnome-keyring-dbg - debugging symbols for pidgin-gnome-keyring
pidgin-guifications - toaster popups for pidgin
pidgin-hotkeys - Configurable global hotkeys for pidgin
pidgin-lastfm - Last.fm plugin for Pidgin
pidgin-latex - Pidgin plugin to display LaTeX formulas
pidgin-libnotify - display notification bubbles in pidgin
pidgin-librvp - MS Exchange RVP instant messaging plugin for Pidgin
pidgin-microblog - Microblogging plugins for Pidgin
pidgin-microblog-dbg - Microblogging plugins for Pidgin (debugging symbols)
pidgin-mpris - sets your available message to your currently playing track
pidgin-mra - Mail.ru Agent protocol plugin for Pidgin IM
pidgin-mra-dbg - Mail.ru Agent protocol plugin for Pidgin IM
pidgin-nateon - Pidgin plugin for NateOn instant messaging service
pidgin-nateon-dbg - debugging symbols of pidgin-nateon
pidgin-openfetion - Fetion protocol plugin for libpurple
pidgin-openpgp - OpenPGP plugin for Pidgin
pidgin-otr - Off-the-Record Messaging plugin for Pidgin
pidgin-plugin-pack - Collection of Pidgin plugins
pidgin-privacy-please - plugin for enhanced privacy in pidgin
pidgin-sipe - Pidgin plugin for MS Office Communicator and MS Lync
There are more of them actually.
How do I remove all of these at once?
Also, I remember there being a package manger in Ubuntu which could be used instead of dpkg and apt (It let you install things and you could easily keep track of them). I forgot the name. If someone knows of such software, please comment it.(It's not synaptic and it had its own Ubuntu page explaining how to use it).
In general, output from APT when removing a single package would tell you if after removing that package, there are other packages that are no longer required and will propose to remove them as well.
I suppose it would be the case if all these plugins where, in fact, installed. Because, apt-cache search pidgin will search for any available package: installable and already installed.
You could merely use apt list pidgin* instead of apt-cache search pidgin. The difference is that the former will display [installed] next to an installed package that appears on the list.
You could use the following command to remove all (if any) pidgin plugins installed: sudo apt remove ^pidgin. (You could also use sudo apt purge ^pidgin to completely remove this package).
Regarding the package manager, it's hard to tell, you could be speaking of Ubuntu Software Center. Else, I can't tell.
Chaale
  • 71
