I frequently need to check which packages are installed, and I use the following command:
dpkg -l | grep foo
which gives the following output
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Cfg-files/Unpacked/Failed-cfg/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                       Version         Description
ii   foo                       <version>         <description>
- What does the iimean?
- What other flags are there?
- How to read the flags? (because the explanation is quite complicated, IMO)
Thanks.
