I have run the following command to remove old kernels:
dpkg -l 'linux-*' | sed '/^ii/!d;/'"$(uname -r | sed "s/\(.*\)-\([^0-9]\+\)/\1/")"'/d;s/^[^ ]* [^ ]* \([^ ]*\).*/\1/;/[0-9]/!d' | xargs sudo apt-get -y purge
and only the current kernel is now installed, which I have confirmed in synaptic and by checking my boot partition. However, when I run:
dpkg --list | grep linux-image
I get the following response:
rc  linux-image-3.13.0-30-generic                         3.13.0-30.55                                        amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
rc  linux-image-3.13.0-32-generic                         3.13.0-32.57                                        amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-3.13.0-34-generic                         3.13.0-34.60                                        amd64        Linux kernel image for version 3.13.0 on 64 bit x86 SMP
rc  linux-image-extra-3.13.0-30-generic                   3.13.0-30.55                                        amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
rc  linux-image-extra-3.13.0-32-generic                   3.13.0-32.57                                        amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-extra-3.13.0-34-generic                   3.13.0-34.60                                        amd64        Linux kernel extra modules for version 3.13.0 on 64 bit x86 SMP
ii  linux-image-generic                                   3.13.0.34.40                                        amd64        Generic Linux kernel image
Probably not a problem, but just wondering why versions -30 and -32 are reported as present?
Zanna
  • 72,312
The answer is indeed in the first two letters of the line. The first column is a desired state and the second column is a current state. Relevant to this list is:
i = installed
r = remove(d)
c = config files
Thanks to steeldriver for directing my attention.
Zanna
  • 72,312
