I am using Ubuntu 12.04. I found my root directory full so thought to free up some space. In this regard I opt for removing KILE. But the base package KILE is only 4.4 MB.
How can I remove its related libraries (nearly 300MB) which were installed with it?
Eliah Kagan
  • 119,640
Try
sudo apt-get remove --purge kile
and
sudo apt-get autoremove --purge
This should remove any leftover KDE dependencies (as long as there is no other KDE program installed, that depends on them)
Glutanimate
  • 21,763
You can list the kde-depencies with dpkg -l | grep kde. Output is something like this:
rc  kdebase-bin              4:4.6.5-0ubuntu1    core binaries for the KDE base applications
rc  kdebase-workspace-bin    4:4.6.5-0ubuntu1    core binaries for the KDE Plasma Workspace
Now you can manually remove all unwanted kde packages, but be careful if there are packages that not belongs to kde. If you use other kde applications, then those applications need kde-depencies.
See: What do the various dpkg flags like 'ii' 'rc' mean?
BuZZ-dEE
  • 14,533
To remove KDE libraries, use command below. Open terminal (Ctrl+Alt+T) then type:
sudo apt-get remove kubuntu-desktop --purge
sudo apt-get remove kde-base --purge
Then restart your computer. The KDE libraries will be removed.
jokerdino
  • 41,732
