When I try to google how to do this, all the results I get are "How to fix broken packages".
Could you give me a hint how to only list them in the console one by one?
You can list broken packages :
dpkg -l | grep ^..r
r state (on the third field) means: reinst-required (package broken, reinstallation required)
To get the list of partially installed packages (with architecture information) preceded by their states, one by line, run
dpkg-query -W -f='${db:Status-Abbrev} ${binary:Package}\n' | grep -E ^.[^nci]
See man dpkg-query for information about the states etc. (I suppose the Reinst-required i.e. R flag can not appear with states n, c or i. If it could, the extended regular expression in grep command should be modified.)
I did a dist-upgrade which completed, but had puked some errors during the process. So I wanted to validate the errors weren't merely just noise.
apt-get check -v returned NO faults.
HOWEVER: Suspicious the previous command didn't provide correct feedback, I next executed:
dpkg -C
This command DID validate the errors
Given the above experience, I'd suggest not to take the output of apt-get check -v as the gospel everything is clean...
