The command dpkg -l is used to list all installed packages in the system.
But if you look to the output such as below:
ii  whoopsie       0.1.34         Ubuntu crash database submission daemon
rc  wicd-daemon    1.7.2.3-1ubunt wired and wireless network manager - daemon
rc  wicd-gtk       1.7.2.3-1ubunt wired and wireless network manager - GTK+ cl
ii  winbind        2:3.6.3-2ubunt Samba nameservice integration server
ii  wine           1:1.7.18-0ubun Microsoft Windows Compatibility Layer (meta-
ii  wine-gecko2.21 2.21-0ubuntu1~ Microsoft Windows compatibility layer (embed
ii  wine-mono0.0.8 0.0.8-0ubuntu1 Microsoft Windows compatibility layer (.NET
rc  wine1.4        1.4.1-0ubuntu1 Microsoft Windows Compatibility Layer (Binar
rc  wine1.4-amd64  1.4.1-0ubuntu1 Microsoft Windows Compatibility Layer (64-bi
rc  wine1.4-i386:i 1.4.1-0ubuntu1 Microsoft Windows Compatibility Layer (32-bi
ii  wine1.6        1:1.6.1-0ubunt Microsoft Windows Compatibility Layer (Binar
you can see the first element is either ii or rc.
So my question what is the meaning of ii and rc?
Maythux
  • 87,123
To get that you need to check the man page of dpkg-query. From man dpkg-query :
The first three columns of the output show the desired action, the package status, and errors, in that order.
          Desired action:
            u = Unknown
            i = Install
            h = Hold
            r = Remove
            p = Purge
          Package status:
            n = Not-installed
            c = Config-files
            H = Half-installed
            U = Unpacked
            F = Half-configured
            W = Triggers-awaiting
            t = Triggers-pending
            i = Installed
          Error flags:
            <empty> = (none)
            R = Reinst-required
heemayl
  • 93,925
Quoted from https://linuxprograms.wordpress.com/2010/05/11/status-dpkg-list/
Status of every package is represented by three characters xxx
The first character signifies the desired state
u: Unknown (an unknown state)
i: Install (marked for installation)
r: Remove (marked for removal)
p: Purge (marked for purging)
h: Hold
The second character signifies the current state, whether it is installed or not.
n: Not- The package is not installed
i: Inst – The package is successfully installed
c: Cfg-files – Configuration files are present
u: Unpacked- The package is stilled unpacked
f: Failed-cfg- Failed to remove configuration files
h: Half-inst- The package is only partially installed
W: trig-aWait
t: Trig-pend
The third Character corresponds to the error state.
R: Reinst-required The package must be installed.
Then
rc comes to packages remove with config files present
ii comes to packages marked for installation and it's successfully installed
A.B.
  • 92,125
Maythux
  • 87,123
