I tried to dpkg -i --force-architecture google-earth-stable_i386.deb and it failed.
But now when I try to install the amd64.deb it fails saying
dpkg: error processing google-earth-stable_current_amd64.deb (--install): google-earth-stable: 6.2.2.6613-r0 (Multi-Arch: no) is not co-installable with google-earth-stable:i386 6.2.2.6613-r0 (Multi-Arch: no) which is currently installed Errors were encountered while processing: google-earth-stable_current_amd64.deb
somehow it thinks the i386 version is installed. No google-earth files or directories even exist.
sudo dpkg --configure -a
outputs:
dpkg: dependency problems prevent configuration of google-earth-stable:i386: google-earth-stable:i386 depends on lsb-core (>= 3.2). dpkg: error processing google-earth-stable:i386 (--configure): dependency problems - leaving unconfigured Errors were encountered while processing: google-earth-stable:i386
so it does exist in some capacity.
sudo apt-get -f install
does nothing out of the ordinary:
Reading package lists... Done Building dependency tree Reading state information... Done 0 upgraded, 0 newly installed, 0 to remove and 10 not upgraded.
The weird thing is that synaptic doesn't show any google earth package available let alone installed, nothing under the broken filter either.
I have also tried sudo apt-get autoremove and sudo apt-get autoclean
So, my question: How can I get rid of this issue?
ish
  • 141,990
TryTryAgain
  • 1,038
Couldn't install doesn't mean dpkg didn't try and give up half-way
There's nothing complicated about it. Observe this re-enactment:
$ sudo dpkg -i --force-architecture google-earth-stable_current_i386.deb
$ dpkg --list | grep google-earth iU google-earth-stable:i386 6.0.3.2197-r0
The iU tells you that you wanted this package i-nstalled, but dpkg couldn't configure it, so it was leaving it U-nconfigured, waiting for you to fix it. The error you got dpkg: error processing google-earth-stable:i386 (--configure): dependency problems - leaving unconfigured tells you as much in simpler language.
dpkg must be explicitly told to remove a failed install
Just tell dpkg to not bother and remove the package:
sudo dpkg --remove google-earth-stable:i386
And then try installing the 64-bit package again.
Synaptic and apt-get don't care about one-off debs
You got nothing out of Synaptic or apt-get because they aren't aware of your problem. They concern themselves primarily with packages available in the repositories, which you manage through them. They are higher level tools which use dpkg under the hood, but don't care about any problems you create with dpkg unless it concerns them. If you tried to install any package, or Google Earth 64-bit if it was in some repository, with Synaptic or apt-get, they would definitely have whined about it.
Other helpful references
  • The .deb file name and package name are usually different. You need the package name to do any operations with dpkg. Use dpkg --list | grep xxxxx where xxxxx is a small part of the file name sure to be in there, like google or earth.
  • See this answer for a great explanation of all the two-letter dpkg status flags.
ish
  • 141,990
