78
Update Manager will not update even though I have over 100 updates to install. I get a error message like this:
installArchives() failed:
Extracting templates from packages: 29%%
Extracting templates from packages: 58%%
Extracting templates from packages: 88%%
Extracting templates from packages: 100%%
Preconfiguring packages ...
(Reading database ...
(Reading database ... 5%%
(Reading database ... 10%%
(Reading database ... 15%%
(Reading database ... 20%%
(Reading database ... 25%%
(Reading database ... 30%%
(Reading database ... 35%%
(Reading database ... 40%%
(Reading database ... 45%%
(Reading database ... 50%%
(Reading database ... 55%%
(Reading database ... 60%%
(Reading database ... 65%%
(Reading database ... 70%%
(Reading database ... 75%%
(Reading database ... 80%%
(Reading database ... 85%%
(Reading database ... 90%%
(Reading database ... 95%%
(Reading database ... 100%%
(Reading database ... 189751 files and directories currently installed.)
Preparing to replace python-problem-report 2.0.1-0ubuntu7 (using .../python-problem-report_2.0.1-0ubuntu9_all.deb) ...
Traceback (most recent call last):
  File "/usr/bin/pyclean", line 33, in <module>
    from debpython.namespace import add_namespace_files
ValueError: bad marshal data (unknown type code)
dpkg: warning: subprocess old pre-removal script returned error exit status 1
dpkg - trying script from the new package instead ...
dpkg: error processing /var/cache/apt/archives/python-problem-report_2.0.1-0ubuntu9_all.deb (--unpack):
 subprocess new pre-removal script returned error exit status 1
No apport report written because MaxReports is reached already
  File "/usr/bin/pycompile", line 39, in <module>
dpkg: error while cleaning up:
 subprocess installed post-installation script returned error exit status 1
Preparing to replace python-apport 2.0.1-0ubuntu7 (using .../python-apport_2.0.1-0ubuntu9_all.deb) ...
dpkg: error processing /var/cache/apt/archives/python-apport_2.0.1-0ubuntu9_all.deb (--unpack):
Preparing to replace apport 2.0.1-0ubuntu7 (using .../apport_2.0.1-0ubuntu9_all.deb) ...
apport stop/waiting
dpkg: error processing /var/cache/apt/archives/apport_2.0.1-0ubuntu9_all.deb (--unpack):
apport start/running
Preparing to replace gnome-orca 3.4.1-0ubuntu0.1 (using .../gnome-orca_3.4.2-0ubuntu0.1_all.deb) ...
dpkg: error processing /var/cache/apt/archives/gnome-orca_3.4.2-0ubuntu0.1_all.deb (--unpack):
Preparing to replace python-piston-mini-client 0.7.2-0ubuntu1 (using .../python-piston-mini-client_0.7.2+bzr57-0ubuntu1_all.deb) ...
dpkg: error processing /var/cache/apt/archives/python-piston-mini-client_0.7.2+bzr57-0ubuntu1_all.deb (--unpack):
Preparing to replace oneconf 0.2.8 (using .../oneconf_0.2.8.1_all.deb) ...
dpkg: error processing /var/cache/apt/archives/oneconf_0.2.8.1_all.deb (--unpack):
Preparing to replace software-center 5.2.2 (using .../software-center_5.2.2.2_all.deb) ...
dpkg: error processing /var/cache/apt/archives/software-center_5.2.2.2_all.deb (--unpack):
Preparing to replace libglade2-0 1:2.6.4-1ubuntu1 (using .../libglade2-0_1%%3a2.6.4-1ubuntu1.1_amd64.deb) ...
Unpacking replacement libglade2-0 ...
Preparing to replace libv4l-0 0.8.6-1ubuntu1 (using .../libv4l-0_0.8.6-1ubuntu2_amd64.deb) ...
De-configuring libv4l-0:i386 ...
Unpacking replacement libv4l-0 ...
Preparing to replace libv4l-0:i386 0.8.6-1ubuntu1 (using .../libv4l-0_0.8.6-1ubuntu2_i386.deb) ...
Unpacking replacement libv4l-0:i386 ...
Preparing to replace libv4lconvert0:i386 0.8.6-1ubuntu1 (using .../libv4lconvert0_0.8.6-1ubuntu2_i386.deb) ...
De-configuring libv4lconvert0 ...
Unpacking replacement libv4lconvert0:i386 ...
Preparing to replace libv4lconvert0 0.8.6-1ubuntu1 (using .../libv4lconvert0_0.8.6-1ubuntu2_amd64.deb) ...
Unpacking replacement libv4lconvert0 ...
Error in function:
SystemError: E:Sub-process /usr/bin/dpkg returned an error code (1)
Setting up libglade2-0 (1:2.6.4-1ubuntu1.1) ...
dpkg: error processing gnome-orca (--configure):
 Package is in a very bad inconsistent state - you should
 reinstall it before attempting configuration.
dpkg: error processing python-problem-report (--configure):
Setting up libv4lconvert0 (0.8.6-1ubuntu2) ...
Setting up libv4lconvert0:i386 (0.8.6-1ubuntu2) ...
dpkg: error processing python-piston-mini-client (--configure):
Setting up libv4l-0 (0.8.6-1ubuntu2) ...
Setting up libv4l-0:i386 (0.8.6-1ubuntu2) ...
dpkg: dependency problems prevent configuration of python-apport:
 python-apport depends on python-problem-report (>= 0.94); however:
  Package python-problem-report is not configured yet.
dpkg: error processing python-apport (--configure):
 dependency problems - leaving unconfigured
dpkg: dependency problems prevent configuration of software-center:
 software-center depends on python-piston-mini-client (>= 0.1+bzr29); however:
  Package python-piston-mini-client is not configured yet.
dpkg: error processing software-center (--configure):
dpkg: dependency problems prevent configuration of oneconf:
 oneconf depends on python-piston-mini-client (>= 0.3+bzr32-0ubuntu1); however:
dpkg: error processing oneconf (--configure):
dpkg: dependency problems prevent configuration of apport:
 apport depends on python-apport (>= 2.0.1-0ubuntu7); however:
  Package python-apport is not configured yet.
dpkg: error processing apport (--configure):
Processing triggers for libc-bin ...
ldconfig deferred processing now taking place
This has been going on for two weeks now and I cannot get any updates. Any help would be great.
Braiam
  • 69,112
raz7588
  • 781
7 Answers7
141
You need to force overwriting of the files causing the errors:
sudo dpkg -i --force-overwrite <filename>
In your case it's going to be:
sudo dpkg -i --force-overwrite /var/cache/apt/archives/python-problem-report_2.0.1-0ubuntu9_all.deb
Then run:
sudo apt-get -f install
Source: http://www.absolutelytech.com/2010/06/30/solved-error-dpkg-error-processing-filename-unpack-trying-to-overwrite/
Sparhawk
  • 6,969
David Lartey
  • 1,617
46
You can try the following command:
sudo apt-get clean
sudo apt-get update && sudo apt-get upgrade
If you still end up with the same error, try:
sudo dpkg --configure -a
Even if that doesn't work and you still get the same error, check back and we can sort this out.
jokerdino
  • 41,732
It might be a bug in the python-problem-report package or python-minimal package or a bad copy of the package.
I see that this is package from precise-proposed. You may wish to delete this repository from your software sources list and execute apt-get update from a terminal session (Ctrl-Alt-T) to recover.
You can also try deleting python-problem-report_2.0.1-0ubuntu9_all.deb from /var/cache/apt/archives so apt-get upgrade will have to download a fresh copy again. In the terminal (Ctrl-Alt-T) type:
sudo rm /var/cache/apt/archives/python-problem-report_2.0.1-0ubuntu9_all.deb
Alternatively you can use:
sudo apt-get clean
to erase all of the downloaded files in your cache.
Try the upgrade again.
If neither of these help you should leave a comment at https://bugs.launchpad.net/ubuntu/+source/apport/+bug/984944 describing your experience in using this proposed package, or once the package is generally release, file a bug against the apport package.
I've left one comment about this question at https://bugs.launchpad.net/ubuntu/+source/apport/+bug/984944 but you should add a comment describing the steps you have gone through and the output from apt-get upgrade from above.
John S Gruber
  • 13,436
sudo update-alternatives --config python
There are 2 choices for the alternative python (providing /usr/bin/python).
  Selection    Path                Priority   Status
  0            /usr/bin/python3.5   2         auto mode
* 1            /usr/bin/python2.7   1         manual mode
  2            /usr/bin/python3.5   2         manual mode
Press <enter> to keep the current choice[*], or type selection number:
Select option python2.7.
karel
  • 122,292
  • 133
  • 301
  • 332
As an alternative, you might try removing the package and adding it afterwards. This worked for me on the Citrix client. Be careful about what you're removing (of course).
sudo apt-get remove icaclient:i386
Eliah Kagan
  • 119,640
I encountered a similar problem on a system which had both python 2.7 and python 3.4 installed. The problem was a compatibility issue with the package python-subversion, which apparently only works with python 2 due to a change in ConfigParser. I addressed it by doing
ls -la /usr/bin | grep python
To confirm that the python executable on my path was a symlink to python 3. Then
ln -s /usr/bin/python2.7 /usr/bin/python
To use python 2 instead. After that apt-get was able to complete normally, and I reverted my symlink change.
rm -f /usr/bin/python
ln -s /usr/bin/python3.4 /usr/bin/python
-3
Try this:
mount -t proc proc /proc
It worked for me.
