I have searched the whole internet including reading everything on google/askubuntu/all ubuntu communities), tried all the possible solution and still didn't figure it out (but I am not google so my indexing and searching algorithm skills might not be that good)
anyways to the point. I am trying to run apt-get update and then apt-get upgrade.
I get the following error:
Reading package lists... Done
Building dependency tree
You might want to run 'apt --fix-broken install' to correct these.
libnvidia-ifr1-390 : Depends: libnvidia-gl-390 but it is not installed
libnvidia-ifr1-390:i386 : Depends: libnvidia-gl-390:i386 but it is not installed
nvidia-driver-390 : Depends: libnvidia-gl-390 (= 390.87-0ubuntu0~gpu18.04.1) but it is not installed
Recommends: libnvidia-gl-390:i386 (= 390.87-0ubuntu0~gpu18.04.1)
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
then i ran apt --fix-broken install .. and got these results
Correcting dependencies... Done
The following additional packages will be installed:
libnvidia-gl-390 libnvidia-gl-390:i386
The following NEW packages will be installed:
0 upgraded, 2 newly installed, 0 to remove and 9 not upgraded.
4 not fully installed or removed.
Need to get 0 B/29.1 MB of archives.
After this operation, 147 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 298882 files and directories currently installed.)
Preparing to unpack .../libnvidia-gl-390_390.87-0ubuntu0~gpu18.04.1_i386.deb ...
diversion of /usr/lib/i386-linux-gnu/libGL.so.1 to /usr/lib/i386-linux-gnu/libGL.so.1.distrib by nvidia-340
dpkg-divert: error: mismatch on package
when removing 'diversion of /usr/lib/i386-linux-gnu/libGL.so.1 by libnvidia-gl-390'
found 'diversion of /usr/lib/i386-linux-gnu/libGL.so.1 to /usr/lib/i386-linux-gnu/libGL.so.1.distrib by nvidia-340'
dpkg: error processing archive /var/cache/apt/archives/libnvidia-gl-390_390.87-0ubuntu0~gpu18.04.1_i386.deb (--unpack):
new libnvidia-gl-390:i386 package pre-installation script subprocess returned error exit status 2
Preparing to unpack .../libnvidia-gl-390_390.87-0ubuntu0~gpu18.04.1_amd64.deb ...
diversion of /usr/lib/x86_64-linux-gnu/libGL.so.1 to /usr/lib/x86_64-linux-gnu/libGL.so.1.distrib by nvidia-340
when removing 'diversion of /usr/lib/x86_64-linux-gnu/libGL.so.1 by libnvidia-gl-390'
found 'diversion of /usr/lib/x86_64-linux-gnu/libGL.so.1 to /usr/lib/x86_64-linux-gnu/libGL.so.1.distrib by nvidia-340'
dpkg: error processing archive /var/cache/apt/archives/libnvidia-gl-390_390.87-0ubuntu0~gpu18.04.1_amd64.deb (--unpack):
new libnvidia-gl-390:amd64 package pre-installation script subprocess returned error exit status 2
i tried all the tricks like apt clean/remove/dist upgrade/whatever apt i found on the net without luck.
any help is really appricated.
