I'm a brand new linux/ubuntu user. I've been able to fix some basic things, but this I'm having trouble with.
OS/Version is:
Distributor ID: Ubuntu Description: Ubuntu 22.04 LTS Release: 22.04 Codename: jammy
I keep getting that the The following packages have unmet dependencies: with the apt--fix-broken install as a recommended fix. However, this only results in the following:
matt@matt-MS-7C02:~$ sudo apt-get autoremove
[sudo] password for matt:
Reading package lists... Done
Building dependency tree... Done
You might want to run 'apt --fix-broken install' to correct these.
libgl1-mesa-dri : Depends: libglapi-mesa (= 22.0.1-1ubuntu2.1) but 22.1.3+git2206301758.a066287f1b5~j~mesarc0 is installed
Breaks: libgl1-mesa-dri:i386 (!= 22.0.1-1ubuntu2.1) but 22.1.3+git2206301758.a066287f1b5~j~mesarc0 is installed
libgl1-mesa-dri:i386 : Breaks: libgl1-mesa-dri (!= 22.1.3+git2206301758.a066287f1b5~j~mesarc0) but 22.0.1-1ubuntu2.1 is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
matt@matt-MS-7C02:~$ sudo apt--fix-broken install
sudo: apt--fix-broken: command not found
matt@matt-MS-7C02:~$ sudo apt --fix-broken install
Correcting dependencies... Done
The following additional packages will be installed:
libgl1-mesa-dri
The following packages will be upgraded:
libgl1-mesa-dri
1 upgraded, 0 newly installed, 0 to remove and 53 not upgraded.
2 not fully installed or removed.
Need to get 0 B/7,878 kB of archives.
After this operation, 12.3 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 215762 files and directories currently installed.)
Preparing to unpack .../libgl1-mesa-dri_22.1.3+git2206301758.a066287f1b5~j~mesar
c0_amd64.deb ...
Unpacking libgl1-mesa-dri:amd64 (22.1.3+git2206301758.a066287f1b5~j~mesarc0) ove
r (22.0.1-1ubuntu2.1) ...
dpkg: error processing archive /var/cache/apt/archives/libgl1-mesa-dri_22.1.3+gi
t2206301758.a066287f1b5~j~mesarc0_amd64.deb (--unpack):
trying to overwrite '/usr/lib/x86_64-linux-gnu/dri/i915_dri.so', which is also
in package libgl1-amber-dri:amd64 21.3.7-0ubuntu1
/var/cache/apt/archives/libgl1-mesa-dri_22.1.3+git2206301758.a066287f1b5~j~mesa
rc0_amd64.deb
What could I do to fix this broken dependencies?
