I am trying to do an upgrade on Ubuntu 14.04. I run:
sudo apt-get -u dist-upgrade
When I run that, I get this error:
dpkg: error processing archive /var/cache/apt/archives/linux-image-3.13.0-24-generic_3.13.0-24.47~precise2_amd64.deb (--unpack):
Here's the entire output:
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
The following packages will be upgraded:
1 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 0 B/52.3 MB of archives.
After this operation, 155 MB of additional disk space will be used.
Do you want to continue? [Y/n] Y
(Reading database ... 63480 files and directories currently installed.)
Preparing to unpack .../linux-image-3.13.0-24-generic_3.13.0-24.47~precise2_amd64.deb ...
Done.
Unpacking linux-image-3.13.0-24-generic (3.13.0-24.47~precise2) over (3.13.0-24.46) ...
 trying to overwrite '/lib/modules/3.13.0-24-generic/kernel/mm/hwpoison-inject.ko', which is also in package linux-image-extra-3.13.0-24-generic 3.13.0-24.46
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Examining /etc/kernel/postrm.d .
run-parts: executing /etc/kernel/postrm.d/initramfs-tools 3.13.0-24-generic /boot/vmlinuz-3.13.0-24-generic
run-parts: executing /etc/kernel/postrm.d/zz-update-grub 3.13.0-24-generic /boot/vmlinuz-3.13.0-24-generic
How do I resolve this? Thanks!
Di Zou
  • 161
