When running sudo apt -qq update the terminal gives me this:
sudo apt dist-upgrade
Reading package lists... Done
Building dependency tree
You might want to run 'apt-get -f install' to correct these.
libphonon4 : Depends: libqtcore4 (>= 4:4.8.1) but it is not installed
libqt4-declarative : Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but it is not installed
libqt4-network : Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but it is not installed
libqt4-opengl : Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but it is not installed
libqt4-script : Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but it is not installed
libqt4-sql : Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but it is not installed
libqt4-sql-sqlite : Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but it is not installed
libqt4-xml : Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but it is not installed
libqt4-xmlpatterns : Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but it is not installed
libqtdbus4 : Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but it is not installed
libqtgui4 : Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but it is not installed
musique : Depends: libqtcore4 (>= 4:4.8.0) but it is not installed
phonon-backend-gstreamer : Depends: libqtcore4 (>= 4:4.8.1) but it is not installed
qdbus : Depends: libqtcore4 (= 4:4.8.7+dfsg-5ubuntu2) but it is not installed
qt-at-spi : Depends: libqtcore4 (>= 4:4.8~) but it is not installed
E: Unmet dependencies. Try using -f.
And when I run sudo apt-get install -f to install the missing packages it gives me this:
The following additional packages will be installed:
libqtcore4
The following NEW packages will be installed:
libqtcore4
0 upgraded, 1 newly installed, 0 to remove and 20 not upgraded.
17 not fully installed or removed.
Need to get 0 B/1 552 kB of archives.
After this operation, 5 092 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
(Reading database ... 234467 files and directories currently installed.)
Preparing to unpack .../libqtcore4_4%3a4.8.7+dfsg-5ubuntu2_amd64.deb ...
Unpacking libqtcore4:amd64 (4:4.8.7+dfsg-5ubuntu2) ...
dpkg: error processing archive /var/cache/apt/archives/libqtcore4_4%3a4.8.7+dfsg-5ubuntu2_amd64.deb (--unpack):
trying to overwrite shared '/etc/xdg/Trolltech.conf', which is different from other instances of package libqtcore4:amd64
dpkg-deb: error: subprocess paste was killed by signal (Broken pipe)
Processing triggers for libc-bin (2.23-0ubuntu5) ...
How should I proceed?
