I recently upgraded to the 18.04 ubuntu, but the download did not go so well. When it finished my laptop said that it "installed" but with errors. I have tried the following commands in the terminal, and now I am just going in circles. I have been using Ubuntu for a while but I am at the end of my abilities.
I ran
sudo apt-get update
then got
Hit:1 http://archive.ubuntu.com/ubuntu bionic InRelease
Hit:2 http://archive.ubuntu.com/ubuntu bionic-updates InRelease
Hit:3 http://archive.ubuntu.com/ubuntu bionic-backports InRelease
Get:4 http://archive.ubuntu.com/ubuntu bionic-security InRelease [69.9 kB]
Fetched 69.9 kB in 1s (56.6 kB/s)
Reading package lists... Done
then nothing. I ran:
sudo apt-get dist-upgrade
and got this:
You might want to run 'apt --fix-broken install' to correct these.
gnome-keyring-pkcs11 : Breaks: libp11-kit-gnome-keyring (< 3.27.4-2~) but 3.20.1-1ubuntu1 is installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
I ran
sudo apt --fix-broken install
then it says:
dpkg: error processing archive /var/cache/apt/archives/libp11-kit-gnome-keyring_3.28.0.2-1ubuntu1_all.deb (--unpack):
libp11-kit-gnome-keyring:all 3.28.0.2-1ubuntu1 (Multi-Arch: no) is not co-installable with libp11-kit-gnome-keyring which has multiple installed instances
I tried running the software update, and it says I have too many third parties working. I went into settings and left the first four checked, nothing. I unchecked all of them, nothing. This is where ive been going around for a bit.
