My Ubuntu Software Center is will not launch. I have read several related question and I have tried various suggestions from Ask Ubuntu including this question, but all attempts return the same error messages. I am running Ubuntu 12.04.
sudo apt-get install --reinstall software-center
sudo apt-get update && sudo apt-get upgrade
sudo apt-get install --reinstall python-pkg-resources
All attempts provide the following errors:
/var/cache/apt/archives/python-problem-report_2.0.1-0ubuntu15.1_all.deb
/var/cache/apt/archives/python-apport_2.0.1-0ubuntu15.1_all.deb
 /var/cache/apt/archives/apport_2.0.1-0ubuntu15.1_all.deb
 /var/cache/apt/archives/python-aptdaemon.gtk3widgets_0.43+bzr805-0ubuntu7_all.deb
 /var/cache/apt/archives/python-aptdaemon.pkcompat_0.43+bzr805-0ubuntu7_all.deb
 /var/cache/apt/archives/python-aptdaemon_0.43+bzr805-0ubuntu7_all.deb
 /var/cache/apt/archives/software-center_5.2.6_all.deb
How do I correct these errors and get my system functioning properly?
In response to Lucio's comment:
Running the following two lines of code produced the same errors.
sudo apt-get clean
Continuing with the help file, I ran:
sudo dpkg --configure -a
and received the following errors:
 python-aptdaemon
 apport-gtk
 software-center
 gedit-plugins
 aptdaemon
 update-notifier-common
 python-apport
 flashplugin-installer
 apport
Finally, I ran:
sudo apt-get -f install
but this, again, provided the original errors.
I was installing Python 3.3 to use as the default vice Python2.7. Is any of this (from /usr/bin) creating my problem?
*-rwxr-xr-x  1 root         root             4124 Apr 17  2012 pyclean
*-rwxr-xr-x  1 root         root            11933 Apr 17  2012 pycompile
*lrwxrwxrwx  1 root         root                8 Aug 14 18:02 pydoc -> pydoc2.7
*-rwxr-xr-x  1 root         root               79 Aug  1 01:40 pydoc2.7
*lrwxrwxrwx  1 root         root               12 Aug 14 18:02 pygettext -> pygettext2.7
*-rwxr-xr-x  1 root         root            22103 Aug  1 01:40 pygettext2.7
*-rwxr-xr-x  1 root         root              217 Mar  9  2012 pyhtmlizer
*lrwxrwxrwx  1 root         root               28 Dec 24 01:51 python -> /usr/bin/Python-3.3.0/python
*lrwxrwxrwx  1 root         root                9 Aug 14 18:02 python2 -> python2.7
*-rwxr-xr-x  1 root         root          2989480 Aug  1 01:40 python2.7
*drwxr-xr-x 16 inigomontoya inigomontoya     4096 Dec 24 01:42 Python-3.3.0
*-rw-r--r--  1 root         root         16327785 Sep 29 05:15 Python-3.3.0.tgz
*lrwxrwxrwx  1 root         root               29 Aug 14 18:02 pyversions -> ../share/python/pyversions.py
If the version of python is the issue, can you please post the output of sudo update-alternatives --config python? If it shows python 3.3 as the default, change it to python 2.7 and then re-install the software-center, otherwise the version of python does not seem to be the root-cause.
jobin
  • 28,567
