562
I want to change the OS hostname but I do not want to restart.
I have edited /etc/hostname but it requires a restart to get implemented. How to avoid this?
the
  • 845
14 Answers14
698
It's easy. Just click the Gear icon (located at upper right corner of the screen), open "About this computer" screen (located at Gear icon ) and edit "Device name".
Or, in a terminal, use the following command:
sudo hostname your-new-name
This will set the hostname to your-new-name until you restart. See man hostname and How do I change the computer name? for further information. Do not use _ in your name.
Note
After a restart your changes in /etc/hostname will be used, so (as you said in the question), you should still use
sudo -H gedit /etc/hostname
(or some other editor) so that file contains the hostname.
To test that the file is set up correctly, run:
sudo service hostname start
You should also edit /etc/hosts and change the line which reads:
127.0.1.1     your-old-hostname
so that it now contains your new hostname. (This is required otherwise many commands will cease functioning.)
jasperado
  • 7,448
317
Ubuntu 13.04 onwards
The hostnamectl command is part of the default installation on both Desktop and Server editions.
It combines setting the hostname via the hostname command and editing /etc/hostname. As well as setting the static hostname, it can set the "pretty" hostname, which is not used in Ubuntu. Unfortunately, editing /etc/hosts still has to be done separately.
hostnamectl set-hostname new-hostname
This command is part of the systemd-services package (which, as of Ubuntu 14.04, also includes the timedatectl and localectl commands). As Ubuntu migrates to systemd, this tool is the future.
muru
  • 207,228
66
Without Restart
Changing the hostname or computer name in ubuntu without restart
Edit /etc/hostname and change to the new value,
nano /etc/hostname
Edit /etc/hosts and change the old 127.0.1.1 line to your new hostname
127.0.0.1   localhost
127.0.1.1   ubuntu.local    ubuntu   # change to your new hostname/fqdn
Note : i have read it on a forum > Edit /etc/hosts and change the old 127.0.1.1 line to your new hostname (if you don't do this, you wont be able to use sudo anymore. If you have already done it, press ESC on the grub menu, choose recovery, and edit your host file to the correct settings)
Now after a reboot, your hostname will be the new one you chose
Without Reboot
To change without a reboot, you can just use hostname.sh after you edit /etc/hostname. You must keep both your host names in /etc/hosts (127.0.0.1 newhost oldhost) until you execute the command below:
Note : Above command to make the change active. The hostname saved in this file (/etc/hostname) will be preserved on system reboot (and will be set using the same service).
One Zero
  • 27,761
44
The default name was set when you were installing Ubuntu. You can easily change it to whatever you want in both Desktop & Server by editing the hosts and hostname files. Below is how:
  1. Press CtrlAltt on keyboard to open the terminal. When it opens, run the below command: sudo hostname NEW_NAME_HERE
This will change the hostname until next reboot. The change won’t be visible immediately in your current terminal. Start a new terminal to see the new hostname.
  1. To change the name permanently, run command to edit the host files:
    sudo -H gedit /etc/hostname and sudo -H gedit /etc/hosts
For Ubuntu server without a GUI, run sudo vi /etc/hostname and sudo vi /etc/hosts and edit them one by one. In both files, change the name to what you want and save them.
Finally, restart your computer to apply the changes.
muru
  • 207,228
20
Cloud-init (Ubuntu 18+) hostname persistence
Whilst the above approaches (hostnamectl, etc/hostname, etc) work for immediate hostname change, with the advent of cloud-init - which can control setting of the hostname - amongst many other things. So it won't stick after a reboot if cloud-init is installed. If you want the change to stay after a reboot then you'll need to edit the cloud-init config files, disable cloud-init's hostname set/update module:
sudo sed 's/preserve_hostname: false/preserve_hostname: true/' /etc/cloud/cloud.cfg
or disable cloud-init entirely:
sudo touch /etc/cloud/cloud-init.disabled
Pierz
  • 3,391
17
Here is a script that changes the hostname in the prescribed way. It ensures that not only sudo but also X11 applications continue to function with no restart required.
Usage: sudo ./change_hostname.sh new-hostname
#!/usr/bin/env bash
NEW_HOSTNAME=$1
echo $NEW_HOSTNAME > /proc/sys/kernel/hostname
sed -i 's/127.0.1.1.*/127.0.1.1\t'"$NEW_HOSTNAME"'/g' /etc/hosts
echo $NEW_HOSTNAME > /etc/hostname
su $SUDO_USER -c "xauth add $(xauth list | sed 's/^.*\//'"$NEW_HOSTNAME"'\//g' | awk 'NR==1 {sub($1,"\"&\""); print}')"
Lucas
  • 685
15
Without restart:
  1. change hostname in /etc/hostname
  2. update /etc/hosts accordingly
  3. sudo sysctl kernel.hostname=mynew.local.host
Check your current hostname with hostname -f
Tombart
  • 999
To get your current hostname:
cat /etc/hostname
This can be changed in any text editor. You would also need to update entry other than localhost against 127.0.0.1 in /etc/hosts.
muru
  • 207,228
tagMacher
  • 708
The classical answer to the original poster's question is that, once you've edited /etc/hostname, you make it apply without restart by running hostname(1) with the -F (--file) option as root:
sudo hostname -F /etc/hostname
The hostname(5) handling with /etc/hostname and the said program has been the same in Debian and its derivatives for over twenty years now, and the package providing it has been tagged essential and required, and IIRC the init scripts have literally used the same thing for decades (/etc/init/hostname.conf still contains it), so I have to say I am genuinely puzzled how nobody had mentioned this already :)
Ubuntu 16.04
Solution based on answer from the DigitalOcean Comunity.
Edit hosts file.
$ sudo nano /etc/hosts
Replace oldname with new one.
127.0.0.1 localhost newname
Setup new hostname.
$ sudo hostnamectl set-hostname newname
Jekis
  • 258
  1. Replace the contents of /etc/hostname with the desired hostname (you can edit with sudo nano /etc/hostname)
  2. In /etc/hosts, replace the entry next to 127.0.1.1 with the desired hostname (you can edit with sudo nano /etc/hosts)
  3. Execute sudo service hostname restart; sudo service networking restart
George
  • 417
Ubuntu 16.04
This is without restart and without any terminal use.
  • Go to System Settings -> Details.
  • There it is. Beside Device name, there is a text-box.
  • Edit text-box and close window.
Open terminal. See for yourselves.
(For older versions, the text-box is not editable.)
Zanna
  • 72,312
Tareq
  • 49
sudo /etc/init.d/networking restart
That should do the job I think
I have read the answers, But I think Probably you are looking for this:
Just execute these two commands after editing the /etc/hostname file.
$ sudo service hostname restart
$ exec bash
That's all. No need to restart.Also make sure you also change the name in /etc/hosts file.
Raman
  • 855
  • 24
