I need to use the custom url name which is able to access from all devices in LAN.
I know that it can be changed from the /etc/hosts file
127.0.0.1   myname
127.0.1.1   system09-System-Product-Name
# The following lines are desirable for IPv6 capable hosts
::1     ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
While entering the myname hosts it is available to access myname/urlpath .
It is accessible only for my system.
How can i make this available to access from other system in LAN too ?
Update :
127.0.0.1   allau
192.168.1.16    sul
You should add :
Your Network Ip address          Name you want
Example :
192.168.0.1      My_Pc
127.0.0.1 & 127.0.1.1 are loop-back Ip addresses .
To know your Ip address just type ifconfig in Terminal .
More help Question
nux
  • 39,152
