From the comments, there is confusion here between the local hostname as set by hostnamectl , apache server names, and DNS (Domain Name Service).
HOSTMAME
This is a setting only used on your localhost.
To set the hostname of your local computer, use hostnamectl
sudo hostnamectl set-hostname new_hostname
IMO this is preferable to manually editing /etc/hostname and /etc/hosts as it is a single command, less prone to typos, and less likely to break sudo.
DNS
Domain Name Servers (DNS) is separate and define how computers connect to other computers the "phone book" analogy is used to describe how DNS works, but it is a network so that you can use a name rather then an ip address to connect over a network protocol to a server, ie http://google.com rather then an ip address.
For detailed information on DNS see https://webhostinggeeks.com/guides/dns/ or similar.
This is somewhat related to FQDN - https://serverfault.com/questions/269838/what-is-the-difference-between-a-hostname-and-a-fully-qualified-domain-name
In this discussion I will use FQDN to refer to the network name you use to connect to a server over a network protocol such as http or ssh. DNS servers use FQDN only such as foo.com and not foo, /etc/host can use non FQDN such as foo rather then foo.com or even both.
So at some point, as a part of your web server installation / configuration, you registered one or more FQDN with a DNS provider such as godaddy or similar. These services run and maintain DNS servers and, in your case, map your apache name servers to your public ip address.
NETWORK APPS USE /etc/hosts and DNS servers to resolve FQDN
Network applications will typically look first in /etc/hosts to resolve FQDN to an ip address. If there is no entry in /etc/hosts they will use DNS to resolve the IP address.
No network applications use the information a system administrator writes in /etc/hostname to resolve DNS.
NMAP
So when you run nmap, it uses reverse DNS service and /etc/hosts to resolve FQDN.
See the nmap documentation for details - https://nmap.org/book/man-host-discovery.html
See also this discussion on server fault - https://serverfault.com/questions/153776/nmap-find-all-alive-hostnames-and-ips-in-lan
There is probably some option or configuration to force nmap to use /etc/hosts or disable DNS lookup, and perhaps someone will post that information here, but it is beyond this discussion.
The short answer is nmap, ssh, http, and other network protocols use DNS and/or reverse DNS lookup to resolve your FQDN to an ipaddress as defined by DNS servers or /etc/hosts and not /etc/hostname on either your local machine or the remote server.
SSH
SSH will use both /etc/hosts and DNS servers.
See the ssh documentation or https://linux-tips.com/t/disabling-reverse-dns-lookups-in-ssh/222 for how to disable ssh from useing DNS services.
If ssh is not returning the hostname you expect you need to investigate further, see https://serverfault.com/questions/266897/why-is-hostname-lookup-in-ssh-returning-a-different-result for details on how to do this.
So in your case I assume ssh is also using DNS services rather then relying only on /etc/hosts to resolve FQDN you are using on the command line.
My practice
I personally do not use my apache FQDN for my local hostname nor do I use my FQDN to ssh into my server nor do I typically pass FQDN to nmap nor do I use NMAP to determine the local hostname of a server.
nmap will tell you the FQDN registered to a FQDN if it exists it does not tell you what is in /etc/hostname of the remote server.
See Apache error "Could not reliably determine the server's fully qualified domain name"
Example:
NMAP by ip address
This works assuming the ip address is public and the remote host is up and not firewalled to block nmap ;)
bodhi@daemon:~$nmap --top-ports 10 8.8.8.8
Starting Nmap 7.40 ( https://nmap.org ) at 2017-06-28 16:10 MDT
Nmap scan report for google-public-dns-a.google.com (8.8.8.8)
Host is up (0.081s latency).
PORT STATE SERVICE
21/tcp filtered ftp
22/tcp filtered ssh
23/tcp filtered telnet
25/tcp filtered smtp
80/tcp filtered http
110/tcp filtered pop3
139/tcp filtered netbios-ssn
443/tcp open https
445/tcp filtered microsoft-ds
3389/tcp filtered ms-wbt-server
Nmap done: 1 IP address (1 host up) scanned in 2.15 seconds
NMAP by FQDN
This also works as long as the name you give is a registered FQDN
bodhi@daemon:~$nmap --top-ports 10 google.com
Nmap scan report for google.com (172.217.11.238)
Host is up (0.10s latency).
Other addresses for google.com (not scanned): 2607:f8b0:400f:800::200e
rDNS record for 172.217.11.238: den02s01-in-f14.1e100.net
PORT STATE SERVICE
21/tcp filtered ftp
22/tcp filtered ssh
80/tcp open http
443/tcp open https
Nmap done: 1 IP address (1 host up) scanned in 2.36 seconds
NMAP with a bogus / non exisstant FQDN
bodhi@daemon:~$nmap foo.bar
**Failed to resolve "foo.bar".**
WARNING: No targets were specified, so 0 hosts scanned.
Nmap done: 0 IP addresses (0 hosts up) scanned in 0.55 seconds
If you are having difficulty we need specific information.
- Post the contents of
- Tell us the FQDN of all your registered domain names
- post the relevant sections of your apache configuration files
- Post the exact nmap and ssh commands you are running and their output.
Without further information we can not clarify any confusion between your local hostname and a network FQDN or debug your connections if the FQDN are not resolving to the remote server you expect.
