When I installed Ubuntu I named my computer "test"
after the installation was finished, I renamed the hostname to somewhat nicer:
sudo hostname silversurfer
And I added the hostname to /etc/hosts
But still even after a reboot, in syslog all messages are preceeded by "test":
tail -f /var/log/syslog
Feb 24 04:51:28 test ntpd[4598]: peers refreshed
Feb 24 04:51:28 test ntpd[4598]: Listening on routing socket on fd #24 for interface updates
My /etc/hosts/ looks like this:
127.0.0.1   localhost
127.0.1.1   test silversurfer
# The following lines are desirable for IPv6 capable hosts
::1     ip6-localhost ip6-loopback
fe00::0 ip6-localnet
ff00::0 ip6-mcastprefix
ff02::1 ip6-allnodes
ff02::2 ip6-allrouters
rubo77
  • 34,024
  • 52
  • 172
  • 299
I found out:
the first hostname for 127.0.1.1 in /etc/hosts is mentioned in syslog, so you have to change:
127.0.0.1   localhost
127.0.1.1   silversurfer test
rubo77
  • 34,024
  • 52
  • 172
  • 299
To change the hostname Permanently Edit the file /etc/hosts
# vi /etc/hosts
127.0.0.1       localhost
192.168.1.100    sambafileserver    samba
Setting up Hostname in /etc/hostname file
# echo "Your Hostname Herer" > /etc/hostname
# hostname -F /etc/hostname
Example:
# echo "sambafileserver" > /etc/hostname
Then Restart the Desktop or Server.
Logs file which Created Before hostname change will be in test.
