Can someone tell me how to change the computer name on a pc, I've tried to edit the /etc/hostname file but it won't allow me access to save the amended file, thought the user the system created was the administrator obviously not.
Thanks
BuZZ-dEE
  • 14,533
Changing the hostname or computer name in ubuntu
Edit /etc/hostname and change to the new value, for example name we are using hostname Ubuntu
sudo nano /etc/hostname
Ubuntu
Edit /etc/hosts and change the old 127.0.1.1 line to your new hostname
127.0.0.1   localhost
127.0.1.1   ubuntu.local    ubuntu   # change to your new hostname/fqdn
Note : Edit /etc/hosts and change the old 127.0.1.1 line to your new hostname (if you dont do this, you wont be able to use sudo anymore. If you hav e already done it, press ESC on the grub menu, choose recovery, and edit your host file to the correct settings)
Now after a reboot, your hostname will be the new one you chose
If you want to apply the change without a reboot,
sudo service hostname restart
OR
 sudo /etc/init.d/hostname restart
Note : Above command to make the change active. The hostname saved in this file (/etc/hostname) will be preserved on system reboot (and will be set using the same script we used hostname).
Qasim
  • 22,162
You need to change 2 files and can use the following commands for that...
pkexec nano /etc/hostname
pkexec nano /etc/hosts
Only change the name; nothing else.
Rinzwind
  • 309,379
