30
How do you use terminal to enable Universe source? Or any those 4 from Software Sources: Main, Universe, Restricted, Multiverse Main is on by default and Restricted is on if durring Ubuntu installation i tick Enable Restricted Formats. Answer with line where version checked so it auto detects it. Like command I know for partner but that goes to Other Software tab sudo add-apt-repository "deb http://archive.canonical.com/ $(lsb_release -sc) partner"
Jorge Castro
  • 73,717
Kangarooo
  • 5,223
I finally found answer myself. To put all ubuntu sources to work without clicking them just enter in terminal
sudo add-apt-repository "deb http://archive.ubuntu.com/ubuntu $(lsb_release -sc) main universe restricted multiverse"
So for just "Universe" would be
sudo add-apt-repository "deb http://archive.ubuntu.com/ubuntu $(lsb_release -sc) universe"
You can then check in Software sources it will show it works now. You can delete manually from sudo gedit /etc/apt/sources.list line http://archive.ubuntu.com/ubuntu lucid main universe restricted multiverse and save and see in Software sources nothing is ticked. Then do
& that makes Just universe ticked. For all enabled do
you can add also partner repository with different link (see difference is ubuntu to canonical)
sudo add-apt-repository "deb http://archive.canonical.com/ubuntu $(lsb_release -sc) partner"
$(lsb_release -sc) makes checking your Ubuntu version and putting its name in link. Since 10.04 is called lucid then you can test in terminal lsb_release -sc gives word lucid Thats makes added repository link precise name of your ubuntu Release in Software sources. Wrong word and noting will work.
for all differences in repositories read https://help.ubuntu.com/community/Repositories/Ubuntu
Kangarooo
  • 5,223
26
As of Ubuntu 12.10, you can run:
sudo add-apt-repository universe
Which is easier than running sed over sources.list files, and will take into account which of -updates/-proposed/-backports is enabled.
You can go back with the --remove flag, but you'll still have to remove the packages:
sudo aptitude purge '~i ~s universe/'
Tobu
  • 473
Universe is enabled by default so you usually don't need to do this. You could edit the sources file from the terminal:
sudoedit /etc/apt/sources.list
And then uncomment the universe sections of the following lines:
#deb http://us.archive.ubuntu.com/ubuntu/ precise universe
#deb http://us.archive.ubuntu.com/ubuntu/ precise-updates universe
The Ubuntu help page may be of use. And if you want to enable it via the GUI:
